just changed alt and now battery light is on
Old May 20, 2006 | 07:15 PM
bleedblue94's Avatar
Default just changed alt and now battery light is on
so i changed out my alternator bc the voltage regulator was taking a crap on me...switched it out everythings fine...then i go and start the car and the battery light is on and im hearing a slight whining sound coming from the alt....voltage is right where it should be any ideas???
also the belt is on snugly
EDIT ALTERNATOR WAS SHOT
Modified by bleedblue94 at 1:32 PM 5/21/2006
Old May 20, 2006 | 07:25 PM
t0p_sh0tta's Avatar
Default Re: just changed alt and now battery light is on (bleedblue94)
Is the battery still good? The old alt might have taken it out along with it.
Old May 20, 2006 | 07:39 PM
Default Re: just changed alt and now battery light is on (t0p_sh0tta)
i know ther battery is good... i guess ill double check the tension tomorrow
Old May 20, 2006 | 07:44 PM
highroller54's Avatar
if the light is on and its charging you got a bad alt.
Old May 20, 2006 | 07:57 PM
Default Re: just changed alt and now battery light is on (highroller54)
? i would think that if the light is on and its not charging then its my alt
meelow
Apr 29, 2010 09:35 PM
bleedblue94
May 20, 2006 04:59 PM
fe519
Sep 23, 2003 03:25 AM
