Bad Valves???
Old May 20, 2006 | 06:23 PM
90jdmcrxdude's Avatar
Default Bad Valves???
I did a b16a swap in my 90 CRX DX that is running really rich and I have changed and tested everything. The only thing left for me to do is to change the valves. Is there any way to test them before taking my car apart. I really dont have to have to do this if I dont have to.
Old May 20, 2006 | 06:25 PM
FalkenSiR's Avatar
Default Re: Bad Valves??? (90jdmcrxdude)
Why would you change the valves if your car is running rich? There's a bunch of stuff to check for to correct that problem. ie: fuel system, bad sensors, etc...
Old May 20, 2006 | 06:26 PM
Default Re: Bad Valves??? (fast95eg8)
Everything has been checked. This is the only thing left.
Old May 20, 2006 | 06:35 PM
FalkenSiR's Avatar
A car runs rich because of other things (like fuel issues), not valves being bad. I say pull the head out and look at the valves first.
Old May 20, 2006 | 06:39 PM
How hard is it to pull the head and check the valves? Ok my problem is that the car is running rich. And blowing black smoke out the exhaust, and coating the back of my car with a coating of black unburned fuel. I brought it to different mechanics and they couldnt figure it out. They changed the O2 sensors, injectors and timing belt. Tested fuel pressure, and sensors. I am running out of options and I need to take the car on a 5 hour trip saturday next weeek and I dont think I'm gonna be able to. Any thing below 4000 rpm the car is bogging out and if I let it idle it almost dies. I just cant think of anything else. Can you?
Old May 20, 2006 | 06:43 PM
FalkenSiR's Avatar
What car, what engine, what ecu? fuel PSI? Tuned?
Old May 20, 2006 | 06:44 PM
Its a 90 CRX DX with a b16a swap I have a chipped PR3 and a virgin PW0 ecus. I dont know the fuel pressure, and its not tuned. Now there is a valve knock and now I'm thinking that maybe I just need to check and see if my valves need to be tightened?
Old May 21, 2006 | 03:31 AM
thahuhstunna's Avatar
try a valve adjustment... if you want to get the head checked out, take it off and take it to a machine shop to have it checked out
Old May 21, 2006 | 10:57 AM
Default Re: Bad Valves??? (thahuhstunna)
I checked the valves and they are all perfect... idk now
curtisb16
Aug 10, 2007 10:56 AM
94HONDAHEAD
May 1, 2007 09:32 AM
jdmjeff
15
Apr 26, 2007 12:58 PM
90jdmcrxdude
May 20, 2006 08:10 PM
