How to tell the difference between a bad head gasket or bad piston rings?
Old May 20, 2006 | 04:00 PM
som3on3_10's Avatar
Default How to tell the difference between a bad head gasket or bad piston rings?
I did a compression test on my car the other day (95 Civic EX) and the readings were approximately:
Cyl 4: 180
Cyl 3: 180
Cyl 2: 150
Cyl 1: 180
So obviously I have a leak. My question is, other than doing a leak down test, how can I tell if it is my head gasket or bad pistons rings based on just doing a compression test? Please help so I can buy the necessary parts to get this car back on the road. Thanks.
Old May 20, 2006 | 04:04 PM
BlueIntegraBoy's Avatar
Default Re: How to tell the difference between a bad head gasket or bad piston rings? (som3on3_10)
Is there water in the oil (is it milky?)?
Old May 20, 2006 | 05:02 PM
som3on3_10's Avatar
No the oil doesn't look milky nor is there any white smoke coming out of my exhaust. I do, however, have to constantly add coolant on a monthly basis.
Old May 20, 2006 | 05:30 PM
Luserkid's Avatar
Default Re: (som3on3_10)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by som3on3_10 &raquo;</TD></TR><TR><TD CLASS="quote"> I do, however, have to constantly add coolant on a monthly basis.</TD></TR></TABLE>
That would tell me headgasket, but you said no smoke or oily water. i would do the headgasket anyway.
Old May 20, 2006 | 05:36 PM
som3on3_10's Avatar
Does the fact that there is no milky oil or white smoke coming from the exhaust automatically rule out a bad head gasket? Or does this just mean that the head gasket is on the verge of going bad since I have to constantly add coolant? And let me add that I have no leaks because I parked my car in the garage last night after letting it run to normal operating temperature and there were no puddles on the ground this morning.
Modified by som3on3_10 at 2:57 AM 5/21/2006
Old May 20, 2006 | 05:39 PM
Luserkid's Avatar
Do you see any leaks in the morning?
Old May 20, 2006 | 05:49 PM
Paxil4x4's Avatar
Default Re: (Luserkid)
Pressure test the cooling system when its cold.
trojan
Feb 26, 2012 02:18 PM
UserX826
10
Oct 29, 2008 12:00 PM
Syndacate
11
Aug 3, 2006 12:02 PM
dc2dragster
Apr 4, 2004 11:16 AM
