Please help with brakes!
Old May 20, 2006 | 03:47 PM
blink3665's Avatar
Default Please help with brakes!
I have a 94 civic vx and just redid the brakes. I put in new SS lines, rotors, and pads. I have bled both front lines. I have a serious problem. When the car is off i can build brake pressure. When i turn the car on the brake goes all the way to the floor. The e-brake works. I have tried rolling and the brake works, just VERY faintly. It would not stop me if i was going anything over 5 MPH. My reservoir was completly empty when i finished. Do i need to bleed the back brakes as well? They are drums in the back. If i do need to do this, can someone tell me how? Thanks!
Old May 20, 2006 | 03:54 PM
Targa250R's Avatar
be professional
Default Re: Please help with brakes! (blink3665)
If you let the reservoir run dry, then you sucked air into the system from the top. You're going to have to bleed all 4 channels now. You're going to need to flush a lot of fluid through the system to push the air all the way through and out.
Old May 22, 2006 | 09:07 AM
blink3665's Avatar
Thanks for the help! I did just that, and the new brakes are great. New (related) question. I had my car in the air for about 8 hours on jack stands in the front. My car now makes a horrid squeaking noise when i go around corners and there is a bump. It seems to only be in the front. any ideas on what that is and how to fix it? I didnt mess with the suspension at all.
Chilly56
Suspension & Brakes
May 19, 2015 03:01 PM
jdmjoka
Dec 16, 2008 06:31 PM
austinkli
23
Oct 31, 2008 06:26 AM
zcivicz
Apr 8, 2005 07:40 PM
bOOsTiNSoHcVtEc
May 11, 2004 12:55 PM
