ticking sound at start up?
Old May 20, 2006 | 03:21 PM
BLUE EH3's Avatar
Help we my pennies
Default ticking sound at start up?
When i go tyo start my car, i hear a ticking sound and then starts right up, its drives fine, no more ticking sound after start up!
what can it be?
Old May 20, 2006 | 03:29 PM
MonkeyBoy668's Avatar
Default Re: ticking sound at start up? (BLUE EH3)
My guess would be the starter solenoid is dying.
AFAIK the solenoids can't be replaced in Hondas unless you pull the starter & rebuild it. So that means you (probably) need a new starter.
If you stick the key in, turn to accessory, let the fuel pump prime, turn to ignition, it clicks several times, then the clicking stops and the engine turns over... that's the starter solenoid.
Old May 20, 2006 | 03:31 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: ticking sound at start up? (MonkeyBoy668)
thats it, so how long do i have to get a new one?
Old May 20, 2006 | 03:53 PM
axtran's Avatar
there's no telling. in the standard denso design (solenoid spins touching two contacts on each side) you can EASILY rebuilt these by getting new contacts, rebolting them internally in the starter, and lightly sanding off any corrosion on the bottom lip of the solenoid.
also, this is a $30 dollar repair compared to $200+ replacing a starter.
Old May 20, 2006 | 05:08 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: (axtran)
guy @ auto zone said it cause b a bad battery
Old May 21, 2006 | 05:07 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: (BLUE EH3)
its the starter!! how long till the start eris toltaly dead!
Old May 21, 2006 | 05:09 PM
5lugSlug's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">its the starter!! how long till the start eris toltaly dead!</TD></TR></TABLE>
i recommend replacing ASAP.. dont worry about time...
Old May 21, 2006 | 05:33 PM
H-adict's Avatar
valves!
Old May 21, 2006 | 05:38 PM
H-adict's Avatar
nevermind!
Old May 21, 2006 | 05:47 PM
EcstasyofGold's Avatar
Just drive it till the starter dies. You can always push start you car... assuming it's a manual.
Get it rolling and dump the clutch in 1st... should start right up without a starter. Or if it's easier to roll it backwards put it in reverse.
Old May 21, 2006 | 06:03 PM
5lugSlug's Avatar
Default Re: (EcstasyofGold)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EcstasyofGold &raquo;</TD></TR><TR><TD CLASS="quote">Just drive it till the starter dies. You can always push start you car... assuming it's a manual.
Get it rolling and dump the clutch in 1st... should start right up without a starter. Or if it's easier to roll it backwards put it in reverse.</TD></TR></TABLE>
or just replace it tomarrow...
Old May 22, 2006 | 10:31 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: (i need a new username)
goin to order it today after work, should be here be 10am tuesday.. pray 4 me
Old May 22, 2006 | 12:30 PM
In my experience it's rather unusual that you're hearing it both click and then start - normally it goes straight from working fine to just clicking and not starting at all. So hey, consider yourself lucky to have had a nice grace period.
Jack Murphy
Jun 21, 2017 06:23 PM
prelude2001h22a
Nov 22, 2014 02:04 PM
old-sk0ol
May 12, 2010 12:41 AM
VM 2
Mar 17, 2009 04:12 AM
Goy091
Jul 7, 2002 06:09 AM
