dumb question
Old May 20, 2006 | 02:37 PM
zccr-xsi's Avatar
Default dumb question
do i have to take the susp. apart?can i just pry the axles out of the tranny and lift out the motor?
only resaon why im asking is cause i need to rip it out in a hurry and i dont want to taer all the susp. apart idf i dont have too.no flaming please i know its dumb question but i need to know asap
ps i dont have to time to search cause im in the middle of ripping the motor out now.
Old May 20, 2006 | 02:51 PM
zccr-xsi's Avatar
anyone?????
Old May 20, 2006 | 04:22 PM
STREETWERKZ's Avatar
Default Re: (vteckillenzc)
no, you dont have to tear apart the suspension....
if you are currently working on it, take a look for yourself.
even if you do, you can probably remove the front suspension faster than it takes most of us to post a response.
good luck.
Old May 20, 2006 | 04:31 PM
zccr-xsi's Avatar
well evrything is ready to come out,all i need to do is losen the mounts up.and yea when i was under there taske the exhsust and shift lingke lose it looks like i can gently pry the axles out and lift the motor out.
Old May 20, 2006 | 05:22 PM
ryanplayjoint's Avatar
You just need to seperate the lower ball joint and pop the axles out of the tranny.
Old May 20, 2006 | 05:29 PM
zccr-xsi's Avatar
its the upper balljoint then slide out the tranny!but thanks ill let yall know what happen.im thinking mainshaft bearing.
Old May 20, 2006 | 05:35 PM
Exempt's Avatar
Yes, you can leave the axles in the hub... When I went to do my swap I a snapped a lug nut (damn Gorilla locking nuts) and couldnt get my wheel off, so I just dropped it from the tranny... As said above, youll have to atleast remove the lower castle nut on the lower ball joint to give you enough room, but its doable... BTW, taking off the upper ball joint alone wouldnt help very much, since with the lower control arm still in place, you wont be able to move the hub the way youll need too, to remove the axle...
Old May 20, 2006 | 05:56 PM
zccr-xsi's Avatar
so i only take off the lower ball joint?if so will i need an tire aliment??
Old May 20, 2006 | 06:27 PM
Exempt's Avatar
Yea, the lower ball joint... No you wont need an alignment... Not unless you mess with the tie rods...
Old May 20, 2006 | 06:47 PM
zccr-xsi's Avatar
Default Re: (Exempt)
thanks!
Old May 20, 2006 | 06:52 PM
wood 1's Avatar
Lower ball joint, pop it out and pull the caliper toward you, th3en take a big screwdriver and pop the axke out of the transmission.
Old May 20, 2006 | 07:14 PM
zccr-xsi's Avatar
any good suggestions on tranny oil?beside honda fuild and gm snycromesh!
Old May 20, 2006 | 07:20 PM
B16CRXT's Avatar
Default Re: dumb question (vteckillenzc)
I always just, take the axle nut off, take the axle out of the hub then pop it out of the tranmission. Takes about 15 minutes. You will have to remove the damper fork to remove teh axle. It is held on by a 17mm bolt/nut on the lca and a 12mm(maybe 14mm...been a while since I messed with that one) pinch bolt on the shock body.
edit: yea, I forgot abt the lower ball joint. Dont touch teh upper ball joint. Thats useless **** there.
I use pennzoil synchromesh from autozone. I dont use anythign else. It cured my 3rd gear grind At least for the time being.
Old May 20, 2006 | 08:49 PM
Exempt's Avatar
Default Re: dumb question (B16CRXT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16CRXT &raquo;</TD></TR><TR><TD CLASS="quote">I use pennzoil synchromesh from autozone. I dont use anythign else. It cured my 3rd gear grind At least for the time being.</TD></TR></TABLE>
Werd, same here... 6 months, no more 3rd gear grind... ::knocks on wood::
Old May 21, 2006 | 05:59 AM
zccr-xsi's Avatar
got a ideal on orice ffor quart on that??
Old May 21, 2006 | 06:23 AM
B16CRXT's Avatar
grab 3 qts. It is less than(or around) $5/qt. I cant remmeber off the top of my head how much exactly..
Old May 21, 2006 | 06:25 AM
zccr-xsi's Avatar
cool! 5$ quart thats checaper then gms ****.good thing i got my autozone gift card.lol
lando griffin
May 11, 2010 09:20 AM
musasabi
Nov 28, 2008 07:13 PM
KOREAN
Oct 30, 2005 09:36 PM
rig9896
Oct 14, 2003 09:49 AM
vtec69
Nov 7, 2002 12:23 PM
