obd0 to obd1 conversion questions?
Old May 20, 2006 | 02:22 PM
robbizza's Avatar
Default obd0 to obd1 conversion questions?
i have a b16a2 in an 89 civic hb, the old owner had the engine (obd2) done up with the original 89 civic wire harness(obd0) so the computer now is obd0 and i want to change it to obd1 what all needs to be changed? i was told just the distributor,computer(obd1)and get an obd0 to obd1 piggyback harness.is that really all and if not,can someone help me out? thanks
Old May 20, 2006 | 02:52 PM
Rywire's Avatar
Default Re: obd0 to obd1 conversion questions? (robbizza)
ya, you do need a obd1 dizzy, and a 4 wire o2(if the ecu looks for it)
Old May 20, 2006 | 05:53 PM
thevtecnician's Avatar
Also, the obd1 ecu looks for a knock sensor. You can install one into your block, but if its a b16a2 it should already have one. Just run the wire to the jumper harness once you buy it, or you could chip your ecu to not use the knock sensor
xsi90teg
Jan 29, 2009 07:32 PM
MniMeHatch89
May 24, 2007 09:10 PM
tRex99
Sep 5, 2004 05:28 PM
KevronsEG
12
Nov 18, 2002 07:57 PM
