what the hell is wrong?!
Old May 20, 2006 | 10:01 AM
Hondaciv95VX's Avatar
Default what the hell is wrong?!
ok, I dont have much info...I was driving, and then i turn my music down, as im pulling into friends drive, i hear a strange noise comming from my car, a rattle squeal, hard to describe. I go in for 10 mins, go to leave to drive home, so I can hopefully find wtf is up with my car, I was going to drive home, cause I figured it could have been making the noise the whole way to my friends, since my music was up i couldnt hear it anyway.
so I drive maybe, 2-3 blocks listening to the sound, rpm related for sure, then it just dies, i was babeing it the 3 blocks, then i feel something break, not violently but nonetheless something broke, then it died at the same time i felt something give i was in 2nd gear at about 1.5k-2k. I pull over, and i give it a crank, knowing i HAVE to get to work soon...wont start, just cranks, i can tell it will nto start...now it sits on the side of the road...
So now, wtf is it, timing belt!??!
I checked what i could for it being dark, and me only having a lighter, i could see all visible belts r ok, now if it is my T belt, i know when these break they can damage valves? what are my chances my motor is still ok...considering my rpms were quite low when whatever happenned happened.
When I go back later, what are some easy to check things...?
What should I look for?
What should I tell my mechanics??
Any advise really woudl be great
uhh yea stock d15z1 186k...if it matters.
P.S. I have a very dieing waterpump, could that breaking cause this? It has been leaking for over a year, and has gotten worse, and has started to do the infamouse dead waterpump rattle...just trying to give as much info as I can.
Thnc for any advice!
Old May 20, 2006 | 10:08 AM
Default Re: what the hell is wrong?! (Hondaciv95VX)
bump
Old May 20, 2006 | 10:09 AM
ufcking's Avatar
I had something similar with mine 95 EX Coupe, if the oil light flickers its the oil pump and I still drove it like that and spun a rod bearing. I am rebuilding my car now. Take it to a mechanic shop before you do serious damage.
Old May 20, 2006 | 10:16 AM
Default Re: what the hell is wrong?! (ufcking)
God I hope its not oil related....I had checked it 1-2 days prior, and never had oil problems befor...expletive, I dont even have a ride to get to my car to even check the oil!!
This week has sucked...seriously.
Old May 20, 2006 | 10:28 AM
schardbody's Avatar
does it crank over a little easier than normal.
Old May 20, 2006 | 10:49 AM
Default Re: (schardbody)
yes...
bad?
Old May 20, 2006 | 10:59 AM
schardbody's Avatar
most likely timing belt, water pump bearing probably seized and threw the belt, hence the breaking sound. take the oil cap off, have someone crank it, watch the rockers, if they dont move, broke the belt.
Old May 20, 2006 | 11:02 AM
Awesome bro, that actually puts me at ease a lil bit...gives me something to check.
Seriosuly thank you!
Old May 20, 2006 | 11:13 AM
schardbody's Avatar
no problem, w/ the rpm's that low theres a SLIGHT chance you didnt hurt anything, but i doubt it.
Old May 20, 2006 | 11:42 AM
oh great...
Good thing the motor is worth 200$...IF that, lol!
Old May 20, 2006 | 12:49 PM
schardbody's Avatar
haha, if that, in good condition they arent worth $200, just get a D15b $600 shipped to your door.
Old May 20, 2006 | 12:57 PM
SovXietday's Avatar
Yeah sorry man, I don't see a happy ending for that engine if you take it apart.
Old May 20, 2006 | 01:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">haha, if that, in good condition they arent worth $200, just get a D15b $600 shipped to your door.</TD></TR></TABLE>
Yea, I may end up doing this...just i cant do the swap : /
Im sure this is an easy question, but if I were to jump on the d15b from hmotors, what all would I need to complete this swap http://www.hmotorsonline.com/s...30019
Old May 20, 2006 | 01:41 PM
schardbody's Avatar
nothing else, except a chipped ecu, P28 or P28.
Old May 20, 2006 | 01:45 PM
vtecspeed1320's Avatar
Shooting Star
Default Re: (Hondaciv95VX)
swapping is the easiest thing to do, my first swap i did about 5 mos ago was an h22 into my ex coupe...you will be alright swapping in another d series into your car.
Old May 20, 2006 | 02:01 PM
Default Re: (vtecspeed1320)
Yea Ive heard some ppl can do a D series in a lunchbreak : / not me
What about the wire harnesses? Cause I know my o2 is a 5 wire, and im sure d15b is a 4...
Is there a page with a lot of this info alrdy, tried search didnt turn up much...
or Where can I find some info on how to rewire it to 4
https://honda-tech.com/zerothread?id=1607567 Found this link, kidna helpful.
Really appreciate all the help, I knwo a lot of this has been coverd on H-T over and voer again, but I have searched, and still am looking.
Old May 20, 2006 | 02:10 PM
schardbody's Avatar
https://honda-tech.com/zerothread?id=635782- ITR Swap into 92-95 VX
all the o2 wiring stuff is the same. if you use a chipped ecu you can get by w/out all that wiring nonsense.
Old May 20, 2006 | 02:12 PM
Man thnc u...I should be done for now...I got a lot of bullshit to go through, on my day off.
Gracias amigos!
Old May 20, 2006 | 02:17 PM
Shooting Star
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaciv95VX &raquo;</TD></TR><TR><TD CLASS="quote">Man thnc u...I should be done for now...I got a lot of bullshit to go through, on my day off.
Gracias amigos!</TD></TR></TABLE>
dont consider it bullshit, consider it a nice way to upgrade performance, just to give you an idea, broke a d16z6 axle, swapped in an h22, spun the h22 bearing, doing a 500-600whp build up with the h2b...upgrades are what the games about.
Old May 20, 2006 | 02:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecspeed1320 &raquo;</TD></TR><TR><TD CLASS="quote">dont consider it bullshit, consider it a nice way to upgrade performance, just to give you an idea, broke a d16z6 axle, swapped in an h22, spun the h22 bearing, doing a 500-600whp build up with the h2b...upgrades are what the games about.</TD></TR></TABLE>
Yea that be great if I didnt have a 30 mile commute to and from work, and I work monday...and no one to car pool w/
By bullshit I mean, getting my car to someplace to work on it, and convincing my bro to borrow me the cash to fix this ****, cause I dont get paid till next week...
Old May 20, 2006 | 03:29 PM
Shooting Star
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaciv95VX &raquo;</TD></TR><TR><TD CLASS="quote">Yea that be great if I didnt have a 30 mile commute to and from work, and I work monday...and no one to car pool w/
By bullshit I mean, getting my car to someplace to work on it, and convincing my bro to borrow me the cash to fix this ****, cause I dont get paid till next week...</TD></TR></TABLE>
yeah ive been down that bullshit kinda road, my car is a daily driver as well. Im not saying you have to go to such an extreme...but the ease of a d series swap is straightforward.
K20_si
Jan 7, 2012 05:35 PM
ej1916
Jan 5, 2012 10:01 AM
hyphenite
Honda Civic (2001 - 2005)
May 26, 2008 09:44 PM
magicmike23
Aug 18, 2007 05:28 PM
beauduvall
Feb 10, 2004 09:05 AM
