motor mount quick?
Old May 20, 2006 | 07:53 AM
2slowCivic's Avatar
Default motor mount quick?
i have a 91 lx with jdm f22b dohc nv swap my front torque rod mount(by radiator) keeps getting destroyed are there any good motor mount kits that will last and where can i get them
thank you
Dan
Old May 20, 2006 | 07:55 AM
honda3x23's Avatar
energy suspension motor mount inserts
http://www.jegs.com best money i've ever spent
Old May 20, 2006 | 05:46 PM
2slowCivic's Avatar
Default Re: (honda3x23)
my ? is does that kit come with all the mounts because the one kit i saw just said rear inserts and the main mount im having issues with is the front one by the radiator looks like a dog bone it is actually called the torque rod. so i just wanna be sure it comes with the insert for that mount as well
Old May 20, 2006 | 06:39 PM
mattf22b1's Avatar
Default Re: (2slowCivic)
get a custom one made its less expensive than getting ones from hasport , and you may want to get an engine damper kit from nrg, just a thought
Old May 21, 2006 | 02:13 PM
twkdCD595's Avatar
Default Re: (mattf22b1)
buy a tube of urethane window weld from 3m... take off the mount, fill it and let it set up/ dry. then re-install and your good to go.
fair warning that urethane mounts (filled or with the inserts) will cause a little more engine vibration to be felt through out the rest of the chassis.
saemoonyang
11
Nov 3, 2011 12:33 PM
old-sk0ol
Aug 8, 2008 06:25 AM
SOHC_Brian
Aug 11, 2004 11:30 AM
inzaneN1
Feb 26, 2004 12:23 AM
