Skunk 2 camber kit
Old May 20, 2006 | 07:45 AM
turnsignalandy's Avatar
Default Skunk 2 camber kit
I have a ej8 lowered on tein s tech springs. I put skunk 2 camber kits up front. The shop that alligned it said they couldnt set the camber at zero, as there was no more adjustment in the camber kit. Can that kit be adjusted more, or are there different versions of the skunk 2 camber kit, because on their site, skunk 2 says their kit can go from +4 to -4 degrees.
Old May 20, 2006 | 11:51 AM
Targa250R's Avatar
be professional
Default Re: Skunk 2 camber kit (turnsignalandy)
The tolerance range for the front camber of a '96-00 Civic is -1.00* through 1.00*, so up to -1.00* of camber is within spec. Camber doesn't have to be set as exact as toe does.
Tein S.Techs are very mild springs and will not need anywhere near 4 degrees of adjustment. Are you sure something on your car isn't severely bent?
Post the complete alignment printout.
Old May 20, 2006 | 12:02 PM
Default Re: Skunk 2 camber kit (Targa250R)
im sure nothins bent. the thing is that 3 months after the alignmnet was done, the f-ers told me that there want enough adjustability to ste the camber to zero. I think they messed up my toe too, because there is NO noticable camber on the fron and after 3 months the insides of my tires are shot.
Old May 20, 2006 | 01:21 PM
if the camber is within the tolerence range, will the tires still wear out quicker if the camber is not 0?
Dirty Octopus
28
Feb 20, 2010 05:47 AM
FLACO EM1
Nov 27, 2008 01:39 PM
doubleshotz
Suspension & Brakes
Nov 2, 2007 05:01 PM
00accordguy
May 21, 2006 09:33 AM
msinsky14
Apr 16, 2006 01:08 PM
