anyone ever warped a v-band flange?
Old May 20, 2006 | 06:30 AM
JCushing's Avatar
Default anyone ever warped a v-band flange?
i was welding it up from the inside for a downpipe (4" SS) so there was no way to clamp the flange down. once i was all done it seemed to warp very slightly. normally id say the bolts or whatever would pull such a small amount of warping in but with a vband flange thats not an option. can you mill these flanges down and have them seal right? i know the width of the flange seems to be important for the clamp to work.
Old May 20, 2006 | 02:15 PM
all_motor_mike's Avatar
Default Re: anyone ever warped a v-band flange? (JCushing)
would it be possible to heat it up and clamp it to its other half to try and straighten it?
Old May 20, 2006 | 05:12 PM
drumking15's Avatar
just take a piece of sand paper on a block of wood....had to straqighten mine out a lil bit after welding it on....
Old May 21, 2006 | 07:59 AM
JCushing's Avatar
Default Re: (drumking15)
no problem with the clamp holding the flange down if its thinned out? looking back i dont see how i could have prevented this... i welded it in sections to try and spread it out but welding on the inside was the only way no not have the bead interfere with the clamp on the outside. i wasnt worried about the bead hurting flow either considering its 4" coming out of the turbine
Old May 21, 2006 | 11:34 AM
Orangecivic251's Avatar
Default Re: (JCushing)
Welding / Fabrication
17
May 7, 2012 03:58 PM
MidShipCivic
12
Mar 5, 2010 05:31 AM
2001ZincSR
Nov 25, 2005 04:48 PM
own6volvos
10
Aug 8, 2005 04:57 PM
Infinity_Racer
Aug 5, 2003 04:37 PM
