Help me Get Rid of it!
i been trying to get rid of this pinging in my car for the past 2 months! i cant seem to find what the problem is,
i have tried ALL KINDS of sprak plugs, gas, fuel cleaners, change wires, changed cap and rotor. i dont know what else to do.
anyone else know what the problem could be?
it only pings from 4000 to about 5000+..
right now im running bosh plat 4 plugs, with 93 oct and the car DOESNT ping...but i dont wanna keep paying $3.50 for plus anymore....
I do not think this will make much differance, but I would recommend OEM Honda plugs (NGK's). Those things are pretty much the best plugs you can use for your Honda, and I have also heard from people in other posts that Bosch plugs are pretty much ****. Also, it might not hurt to try and clean out your motor, put a little Seafoam in there, other than that, I really don't know what to do
Maybe carbon buildup on the pistons has caused a slightly raised compression ratio. I don't know about seafoam but Honda sells a good engine cleaner. Check your local dealership.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaGus »</TD></TR><TR><TD CLASS="quote">i been trying to get rid of this pinging in my car for the past 2 months! i cant seem to find what the problem is,
right now im running bosh plat 4 plugs, with 93 oct and the car DOESNT ping...but i dont wanna keep paying $3.50 for plus anymore.... </TD></TR></TABLE>
make sure timing is ok and not advanced,, if ok,,
try retarding the timing a few degrees,, 3-4 .. and test drive it,,
its a 2002 honda accord coupe....i got a f23a motor but from a 1998 honda accord.
mods are SRI, Header,Muffler tip.
i'v tried SEA FOAM.
i doubt thr piston rings are bad the motor has 35,000 miles on it.
i'm gonna call my honda dealer and pick up a set of 4 plugs and try that out.
also how do i bump the timing on my car??
i'v tried SEA FOAM.
He said 2002, not 2003. That is when the gen changed. You half asleep or something?
First thing you should do is buy a shop manual. Even a cheap one will work. It will do so much better than us trying to explain everything.
FUP23
Jul 27, 2002 01:39 PM
