Main 2nd hitting count 3rd?
My mainshaft 2nd is hitting the bottom outside edge of my countershaft 3rd. Main 2nd is 2-3mm too high. All other gears are fine clearance wise.
D16Y7 trans.
D16Y7 trans.
From: gravity rides everything...everything will fall, se GA/ne FL
damn 2 to 3mm's...make sure the bearing is fully seated. tap it down. if it's botttomed out, i guess do away with some of the washers. might have to do a little math and break the feeler gauges out and spec it.
CPR
Dec 16, 2005 10:38 PM
