WTF do a swap now running rich....
Old May 19, 2006 | 06:58 PM
90jdmcrxdude's Avatar
Default WTF do a swap now running rich....
I did a b16a swap in my 90 crx dx and now it runs really rich.. I have taken it to different mechanics and all they could figure out was the O2 sensors were no good, the injectors were leaky. So I fixed all of that and still nothing. So then I figured out that it was out of time and I fixed that, but still the same thing. I dont know what else it could be I have a PW0 ecu and I am throwing a code 9. I'm getting a new dizzy but everyone says that that wouldnt cause this. I was thinking that maybe it is the valves. But is there any way to test for that. I did a compression check and its 210 across. The back of my car is coated with a film of black ****, that is unburned fuel. I have run out of options and I'm leaving for a 5 hour trip next weekend and I kind of want my car running good. Does anybody have any ideas?
Old May 19, 2006 | 07:02 PM
716pro's Avatar
Default Re: WTF do a swap now running rich.... (90jdmcrxdude)
Map sensor?
Old May 19, 2006 | 07:07 PM
Default Re: WTF do a swap now running rich.... (716pro)
How can I test it? Is the only way to do a electrical test?
Old May 19, 2006 | 07:12 PM
Daniel-sanB1's Avatar
get a fuel pressure gauge, they're like 30$
I was running rich resulting in lost of power.
my fuel pressure was too high, and i had to trouble shoot why.
happy trouble shooting.
Old May 20, 2006 | 03:47 AM
Default Re: WTF do a swap now running rich.... (Daniel-sanB1)
one of the mechanics tested my fuel pressure and it was great
Old May 20, 2006 | 04:00 AM
honda_civic1's Avatar
the code 9 is a #1 cylinder position(CYP)
the CYP sensor which in build into the dizzy determines the position of the cylinder for sequential fuel injection to each cylinder. so i'm pretty sure that when you replace that dizzy you will stop that code and running the way its running now.
you can also check the sensors to see if its preforming right or not.
Old May 20, 2006 | 08:43 AM
Default Re: (honda_civic1)
How do I check that sensor?
I have tried another Dizzy and its the same thing
Old May 20, 2006 | 11:03 AM
716pro's Avatar
Default Re: (90jdmcrxdude)
Try one that you know works.
90jdmcrxdude
11
Mar 13, 2006 08:19 PM
quicksol95
Feb 25, 2005 09:22 AM
dat_flip
Sep 14, 2004 10:11 PM
90TegRex
Jun 11, 2002 07:53 PM
