My CRX build... kinda
Old May 19, 2006 | 05:25 PM
Voodooboy520's Avatar
Default My CRX build... kinda
Before I start, I must say that this was the first time EVER working on a full size car. I had been into Nitro RCs for a couple years so I figured basically how everything worked, but nothing to this detail. I was 17 at the time of start, its been about a year now. I must also mention that I have had noone to help me. At all. I got all my information from the internet . Noone in this area is really into cars, much less swaps, so this WHOLE experience has been possible because of you guys here at H-T and thezcr.com. THANKS GUYS
I picked up my 91 CRX Dx late last summer for $450. It had a snapped cam in the D15b2, and a hideous purple tint to it. I wish I had a picture of that stupid tint because it took me 5 hours to get off with goo gone and a razor blade, but I don’t. Here is a shot before I got it:
Notice the leaking brake master cylinder, I replaced that today. The red wire is from a bazooka tube he had in there that he removed. Throughout the interior, I found literally about 3 times the car’s length in that of wire.
Next came the tampering. I decided the engine swap came first, but I wanted to get my hands dirty. I relocated the battery to the trunk, then began dismantling the engine:
I swear that engine had an endless supply of coolant, because it kept dripping every time I jacked it up. Not long after that it was bye-bye D15
Left to right: Nikki, Jim, Dad, and me.
Ah how I wish I cleaned my engine bay at this point. Its a lot dirtier than it looks in the pic. One of the things I’m most glad about is that I retained my AC, which was a pain to do considering I had to maneuver the transmission around the leftmost vertical lines. You can see the engine mount is right under them. A few weeks later:
The timing belt… well, we’ll say it ended up in 2 trips to the machine shop. It was bad times indeed. Note a second throttle cable – CRX’s here didn’t get cruise control, but my engine had it in Japan. It also had power steering and um, my engine.
Engine prepped to go in
A few months later I was ready to drop it in:
Yeah its doing the gangsta lean because of those AC lines. But now that summer is here I’m really glad I kept them.
From then on I had a bunch of crap go wrong. List, ordered by earliest to latest: Cam position sensor seal, rear main, front main, oil pan gasket, and brake master cylinder. Total cost for the car, including the shell, is probably around $2500 or 3k, I havnt kept receipts. This includes new clutch, flywheel, timing belt, water pump, all seals listed above, rear washer nozzle, battery, and windshield wipers. I get about 36 MPG city, and have yet to test highway. I estimate mid to high 40’s, though. There is probably a lot of little stuff I have forgot to add, but you can probably see it by this very recent picture (aka 2 minutes ago)
[Note to self: Insert picture when the digital camera is not in Florida]
Anyways, I really enjoy driving this car every day. Aside from the awesome gas mileage (Costs me $23 to fill up every 2 weeks), it’s a fun car to drive. My upgrades list is very long, but I’ll hit the high points. This is in order: new brembo brake disks and pads (warped), wider rims and tires, new transmission (ZC 1-4, HF 5th and Si final drive), rear sway, struts and springs, and then who knows what. Thanks for reading, and comments are welcome.
Modified by Voodooboy520 at 11:45 AM 5/20/2006
Old May 19, 2006 | 05:56 PM
CRXBart's Avatar
Default Re: My CRX build... kinda (Voodooboy520)
Sweet a ZC swap is a good place to start. I remember my first swap, a ZC 7years ago in my CRX, Oh how time flies. 2ZC, 1B16, 1B16Rebuild, and now I'm dropping a K20A type-r in. You'll learn allot from your first swap. BTW it is way easier to drop the car on the motor, not drop the motor in the car. I did my first one from the top too. I'm glad I know better now.
Modified by CRXBart at 10:25 PM 5/19/2006
Old May 19, 2006 | 06:19 PM
Targa250R's Avatar
be professional
Get a haircut.
I know what you mean about the window tint; my CRX had some old nasty baked-on tint and I removed it myself too. Talk about a sore arm. I must have spent 4 or 5 hours rubbing off the leftover glue residue.
Old May 20, 2006 | 05:30 AM
Default Re: My CRX build... kinda (CRXBart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote">BTW it is way easier to drop the car on the motor, not drop the motor in the car. I did my first one from the top too. I'm glad I know better now.
I had very limited jack options, and unless I could chain the host to the front crossmemeber or something I dont see how I could drop it on. I definatly thought about it to begin with, but I thought of some issues concerning the rear mount as well.
Old May 20, 2006 | 08:57 AM
DaNnYsEvEn's Avatar
i wish i had that many people helping me out when i did my swap, or atleast someone who was interested in learning about it. i had to do it by myself....sucks.
nice build tho..keep us updated
Old May 20, 2006 | 09:20 AM
EDIT: First paragraph edited.
Modified by Voodooboy520 at 11:46 AM 5/20/2006
Old May 20, 2006 | 09:21 AM
godruler's Avatar
Default Re: (DaNnYsEvEn)
nothing works better for taking off glue left by old tints them a spray bottle filled with good'ol soap and water and rags. i'm telling you nothing, i've used windex, degreasers, wax and grease remover and a **** load of paint thinner and nothing works nearly as well as soap and water.
Old May 20, 2006 | 09:29 AM
STREETWERKZ's Avatar
Default Re: (godruler)
what a great build and first car.
Old May 20, 2006 | 02:42 PM
CRXBart's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voodooboy520 &raquo;</TD></TR><TR><TD CLASS="quote">
I had very limited jack options, and unless I could chain the host to the front crossmemeber or something I dont see how I could drop it on. I definatly thought about it to begin with, but I thought of some issues concerning the rear mount as well. </TD></TR></TABLE>
You don't need no stinking jack. Use your cherry picker. I got a EG Up high enough to drop on a H22 this morning with my picker. I just hook to the strut towers and pick it up. It works great.
Chase1Ratliff
17
Jun 5, 2017 08:19 AM
dylspil
Feb 22, 2016 04:57 PM
408wdy
Appearance Build Threads
244
Sep 14, 2013 07:54 AM
91CRX-VTEC
Jan 16, 2011 12:01 AM
91 crx savage
Oct 14, 2010 03:40 AM
