Someone save my cars life. Im about to take out the hammer.
Old May 19, 2006 | 05:21 PM
OrangeBoost's Avatar
Default Someone save my cars life. Im about to take out the hammer.
I have had it with this car. Ive put so much work into it this year and Im running into problem after problem. Ive run out of patience. Im gonna destroy the POS soon.
Im stumped. I have absolutely no oil pressure. Its a rebuilt d16z6. The oil pump is a brand new OEM pump. I tried turning it over with no fuel to build pressure, nothing. So I poured some oil down my feed line, nothing. Finally I took the cap out of the oil pump and pumped oil in. Still nothing. WTF!
Im cranking about 5 seconds at a time and there is no sign of oil pressure. Im afraid of toasting my bearing at this point.
WTF IS GOING ON!?!??!
Old May 19, 2006 | 05:28 PM
Muckman's Avatar
Moderator in Chief
Default Re: Someone save my cars life. Im about to take out the hammer. (OrangeBoost)
Dude just start it. If it doesnt build pressure in the first 5 secs shut it down.
Old May 19, 2006 | 05:33 PM
SOHCD16y8's Avatar
thats what ive always done.
Old May 19, 2006 | 05:57 PM
b16adx's Avatar
Default Re: Someone save my cars life. Im about to take out the hammer. (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Dude just start it. If it doesnt build pressure in the first 5 secs shut it down.</TD></TR></TABLE>
Thats what I had to do. It wasnt building pressure cranking for 5 secs. I cranked it up and within like 2 secs it had full pressure
Old May 19, 2006 | 06:50 PM
Im not even getting a drop of oil coming out of my feed line! At this point Id say starting it is the last thing I want to do... :S. Im just terrified of killing it.
Old May 19, 2006 | 06:53 PM
coneheadsracing's Avatar
Default Re: (OrangeBoost)
pull your oil filter and see if you have any oil. If your aren't getting oil pressure, depending on where you put your pressure guage, you won't have any oil in your feed line either, for an obvious reason.
Old May 19, 2006 | 06:55 PM
Muckman's Avatar
Moderator in Chief
You've done more damage cranking it over 5 billion times dry than just starting it for 5 seconds. Assembly lube doesnt stay on the bearings forever.
Old May 19, 2006 | 07:36 PM
Default Re: (Muckman)
I know the assembly lube wont stay. Thats why Im afraid.
Old May 19, 2006 | 09:32 PM
Blaze45's Avatar
Brrraaaap!
Start it up, and like muckman said, if you dont have pressure in 5 seconds, shut it down. 5 seconds is a long time but I generally dont see pressure till about 3 seconds after I start my car because if where I have my sensor placed.
Old May 19, 2006 | 10:00 PM
EnzoSpeed's Avatar
Default Re: (Blaze45)
We've all been in this boat. You just have to man up and start it. I was so scared I just about crapped my pants when I started mine for the first time.
By the way, cranking it over isn't supposed to actually build pressure - it's supposed to cut down on the time it takes to build pressure once you actually start the motor. I've never seen pressure register by just cranking it over.
Old May 19, 2006 | 10:43 PM
redzcstandardhatch's Avatar
something different
yeah, cranking cold, your not spinning very many RPM's.
if everthing is put together correctly, you WILL have oil pressure.
Old May 19, 2006 | 11:01 PM
SOHC_MShue's Avatar
well you should be able to get some pressure just cranking it...after a number of cranks it will produce pressure in the feed line for the turbo.
Old May 20, 2006 | 04:00 AM
Default Re: Someone save my cars life. Im about to take out the hammer. (SOHC_MShue)
Even with a finger over the open end of the feedline there isnt even a pulsing.
Old May 20, 2006 | 05:04 AM
non-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OrangeBoost &raquo;</TD></TR><TR><TD CLASS="quote">Even with a finger over the open end of the feedline there isnt even a pulsing.</TD></TR></TABLE>
strart the damn thing......cranking it does not build any pressure when its cold.......especially when its a fresh engine......
Old May 20, 2006 | 05:31 AM
AbitAvenger's Avatar
start it!
Old May 20, 2006 | 11:04 AM
b16adx's Avatar
Default Re: (AbitAvenger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
strart the damn thing......cranking it does not build any pressure when its cold.......especially when its a fresh engine......</TD></TR></TABLE>
Or just stay scared and have a nice paper weight
Old May 20, 2006 | 11:45 AM
warrick's Avatar
Default Re: (b16adx)
check the oil filter? maybe replace it
Old May 21, 2006 | 09:31 AM
Default Re: (warrick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warrick &raquo;</TD></TR><TR><TD CLASS="quote">check the oil filter? maybe replace it</TD></TR></TABLE>
Its new...I wouldnt put an old filter on a new engine.
I guess Ill just have to start it like everyone is saying.
Old May 21, 2006 | 09:32 AM
Schister66's Avatar
Man U FTW
it may be a dumb question, but do you have oil in the car?
Old May 21, 2006 | 10:10 AM
btotherizzle's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">it may be a dumb question, but do you have oil in the car?</TD></TR></TABLE>
hahaha. That's the answer! People are such pansies with their cars. I had a 88 prelude that wouldn't die so I drained all the oil out of it and drove it on the hottest day of the year and it still wouldn't die. I popped the clutch from 8k 5 times and still went. I finally just gave up and drove it to the junkyard. Now go start your ******* car!
Old May 21, 2006 | 06:43 PM
Ahh **** now Ive just had someone tell me that they got a good amount of oil coming out their feed line on their last three engine while cold cranking. That does not make me feel any more confident about just starting it up.
Old May 21, 2006 | 06:49 PM
LSVtechnologytur...'s Avatar
It took me about a min. of cranking on a new motor for the oil light to go off ( i didn't have a pressure gauge) .. then once it went out i just hooked up the dizzy, fuel and started it .. runs fine now
Old May 21, 2006 | 07:41 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Someone save my cars life. Im about to take out the hammer. (LSVtechnologyturboboost)
Just start it already! If you dont get oil pressure in 5 seconds, then shut it off. I highly doubt that running it for that amount of time will toast your engine or your turbo. Did you take the valve cover and filter off and crank it to see if oil spews all over the place yet?
Old May 21, 2006 | 07:55 PM
Pretty please with sugar on top, start the ******* car!!!
Muckman's Avatar
Moderator in Chief
Unsubscribing.
