can I use my dx to obd1 vtec d16 rywire harness later on if I go obd1 b-series?
Old May 19, 2006 | 11:34 AM
wfocrx's Avatar
Default can I use my dx to obd1 vtec d16 rywire harness later on if I go obd1 b-series?
I have a p28 ecu and rywire harness that I'am about to use for my d16z6 in my dx rex. If I decide to go b16 or b18c later on can I use my harness and just get my p28 chipped to work with a bseries?
Old May 19, 2006 | 11:37 AM
court's Avatar
25 Year Member
Default Re: can I use my dx to obd1 vtec d16 rywire harness later on if I go obd1 b-series? (wfocrx)
yes to your whole statement
Old May 19, 2006 | 11:42 AM
wfocrx's Avatar
are the obd1 d16 and obd1 b16 distributors the same?
Iam going through a mid swap crisis. I have the d16z6 engine ready to go in w/ the following parts...
XTD stage 3 clutch and flywheel
new dizzy
new timing belt, water pump, tensioner pulley
motor mount inserts
additonal things I bought that I can reuse are
255lph pump
550cc injectors
p28 ecu
rywire harness
Old May 19, 2006 | 11:45 AM
Boosted90DX's Avatar
Default Re: (wfocrx)
no they are not the same
Old May 19, 2006 | 11:47 AM
court's Avatar
25 Year Member
internally, all obd1 d, b and I belive even h and f series are interchangeable internally.
the case is what sets them appart, the case is what bolts to the head, thats pretty important. even so, obd2 works in this manner as well. for example, I have an obd2 p75 internals in my p28 dizzy case.
hope that answers your Q
Old May 19, 2006 | 12:04 PM
pinecone's Avatar
Default Re: (court)
Yea the internal parts are the same, but the problem mainly comes from mounting the dizzy. Even D series dizzy's aren't interchangable.
nicefighter80
May 21, 2010 01:13 PM
tony7626
Nov 2, 2009 06:45 AM
H22hatchin
Nov 9, 2008 01:10 PM
pane93civhb
Feb 15, 2005 12:35 PM
Nikos
Jul 3, 2003 08:22 AM
