what rev can stock LS bottom handle
Old May 19, 2006 | 11:10 AM
civicgeek133's Avatar
Default what rev can stock LS bottom handle
so i have a ls vtec with a stock b18b bottom end and a b16 head with GSR camsand a B16 tranny i was wondering how high i could rev the stock LS bottom to without messing anything up i have a ecu with a 8500 rev limiter i have only been takin it to 7200 but i was wondering if 8k would be safe on stock rods and bearings i have a type r oil and water pump also on the car thanks for the help
Old May 19, 2006 | 12:41 PM
Spracer03's Avatar
i rev my **** to 8200-8300 daily for like 7 or 9 months now n no problms yet *knocks on wood* and i currently have a completely stock b18b bottow with a gsr head n cams on a ericks ECU... oh and im on a ls water and oil pump
Old May 19, 2006 | 12:49 PM
D-Rob's Avatar
Default Re: (Spracer03)
See 8,000 RPM too much on stock rod bolts and find out what happens...
Old May 19, 2006 | 01:09 PM
Spracer03's Avatar
Default Re: (D-Rob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob &raquo;</TD></TR><TR><TD CLASS="quote">See 8,000 RPM too much on stock rod bolts and find out what happens... </TD></TR></TABLE>I guess its luck of the draw...
Old May 19, 2006 | 02:36 PM
ALLMOTA92EG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spracer03 &raquo;</TD></TR><TR><TD CLASS="quote">I guess its luck of the draw... </TD></TR></TABLE>
lol i know you have been reving that high with stock rod bolts for how long now
Old May 19, 2006 | 02:41 PM
Spracer03's Avatar
Default Re: (D-Rob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob &raquo;</TD></TR><TR><TD CLASS="quote">See 8,000 RPM too much on stock rod bolts and find out what happens... </TD></TR></TABLE>it makes a big difference when you actually take care of your motor and make sure there is oil in it
Old May 19, 2006 | 03:12 PM
DAmn's Avatar
I have been revving to 7500 for nearly a year now without problems, i just dont trust it anymore than that. If you are going to rev it to 8+ the least you can do is make sure you always keep up on oil changes ect. but its likely that your rod bolts will take a dive over time.
Old May 19, 2006 | 03:15 PM
D-Rob's Avatar
Default Re: (DAmn)
Keeping your oil in check doesn't mean anything as far as rod bolt stretch.
Rev that high, and those suckers WILL stretch and you WILL spin a bearing. Give it time.
Old May 19, 2006 | 06:53 PM
Spracer03's Avatar
Default Re: (D-Rob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob &raquo;</TD></TR><TR><TD CLASS="quote">Keeping your oil in check doesn't mean anything as far as rod bolt stretch.
Rev that high, and those suckers WILL stretch and you WILL spin a bearing. Give it time.</TD></TR></TABLE>explain my situation PLEASE and keep in mind my block has upwards of 170k miles
Old May 19, 2006 | 07:25 PM
yea i been worryed bout the rod bolts streching i just got some arp main bolts and bout to order rod bolts also do u think i should upgrade to acl race bearings also while iam in the bottom end ?? and after those do u think its safe to take my car to 8200 ??
Old May 19, 2006 | 09:25 PM
DC4KiD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spracer03 &raquo;</TD></TR><TR><TD CLASS="quote">explain my situation PLEASE and keep in mind my block has upwards of 170k miles </TD></TR></TABLE>
You said it yourself already. "Luck of the draw"... so why need someone else's explaination?
Old May 19, 2006 | 10:00 PM
Spracer03's Avatar
Default Re: (DC4KiD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC4KiD &raquo;</TD></TR><TR><TD CLASS="quote">
You said it yourself already. "Luck of the draw"... so why need someone else's explaination? </TD></TR></TABLE>cause he's making it seem like as soon as the tach hits 8k ur engine goes BOOM, n its not true i know a couple ppl that rev stock ls bottoms to 8k all day long... i dunno about 8500+ but 8k seems to have no problems
Old May 19, 2006 | 10:13 PM
AllMTRWH0R3's Avatar
Default Re: (D-Rob)
Rev that high, and those suckers WILL stretch and you WILL spin a bearing. Give it time.</TD></TR></TABLE>That's right, so it's not recomended. Give or take the trans options given to all and to see where they make most power at will give there shirft points. Now this kid never mentioned power ( didn't read all just skimmed) but you can rev a motor as high as you want all day? did you remember about everything else that can blow? maybe a oil pump can fail and you could be just driving home when that happens. a valve drop just cause your luck of the draw just did happen to run out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicgeek133 &raquo;</TD></TR><TR><TD CLASS="quote">so i have a ls vtec with a stock b18b bottom end and a b16 head with GSR camsand a B16 tranny i was wondering how high i could rev the stock LS bottom to without messing anything up i have a ecu with a 8500 rev limiter i have only been takin it to 7200 but i was wondering if 8k would be safe on stock rods and bearings i have a type r oil and water pump also on the car thanks for the help</TD></TR></TABLE>
You dont have high compression or should have a issue. There is no need to rev that motor to 9100 rpm like I used to ( your setup is way different like mine is so different then others ) Your safe, just tune it and make adjustments to it within your budget Good luck to you bro and have fun first of all.
Old May 20, 2006 | 02:47 AM
Spracer03's Avatar
Default Re: (AllMTRWH0R3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMTRWH0R3 &raquo;</TD></TR><TR><TD CLASS="quote">That's right, so it's not recomended. Give or take the trans options given to all and to see where they make most power at will give there shirft points. Now this kid never mentioned power ( didn't read all just skimmed) but you can rev a motor as high as you want all day? did you remember about everything else that can blow? maybe a oil pump can fail and you could be just driving home when that happens. a valve drop just cause your luck of the draw just did happen to run out.
You dont have high compression or should have a issue. There is no need to rev that motor to 9100 rpm like I used to ( your setup is way different like mine is so different then others ) Your safe, just tune it and make adjustments to it within your budget Good luck to you bro and have fun first of all.</TD></TR></TABLE>true story.. with what this guy has done with motors id take advice from him all day long! but back to the OP i wouldnt worry about revving to 8k on a stock block... no matter what anyone says, besides how many ppl on this forum can say that they spun a rod bearing on a ls block just going to 8k? not 8.2k or 8.4k 8000RPMs? i doubt very many...
Stopsign32v
Mar 7, 2011 10:07 PM
vteck1ck
Mar 15, 2010 06:04 AM
b18 hatch mike
Jul 21, 2007 10:03 PM
AlienKrOZ
Oct 26, 2004 10:30 PM
S2KP
Jan 26, 2004 11:47 AM
