my dyno numbers, Hell yeah!!!!!!!
Old Apr 12, 2002 | 05:49 AM
austrian type-R's Avatar
Default my dyno numbers, Hell yeah!!!!!!!
We was only able to make 1 dyno run, cause my downpipe rubbed on the dynowheel
I have to weld some sheet of metal, cause it is pretty low material there and go on dyno somewhere next week with bigger tires.
There are 1000rpm left, ignition can be advanced and the cam gears are setted to zero/zero. So we did not any modifications.
384.2 bhp / 342 whp at 8000rpm
350 Newtonmeter at ????
Too bad that the printer was out of order so I have no plot.
This was with 1.2 Bar boost in 5th gear. We expect 400+ bhp next dyno session when we are able to drive without rubbing.
Old Apr 12, 2002 | 05:51 AM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Default Re: my dyno numbers, Hell yeah!!!!!!! (austrian type-R)
boost fuggen rocks.
Old Apr 12, 2002 | 05:57 AM
DutchITR1689's Avatar
Nice!! Why 5th gear?
Old Apr 12, 2002 | 05:58 AM
Back in Black's Avatar
Rather OG
Default Re: my dyno numbers, Hell yeah!!!!!!! (DutchITR1689)
Probably because he spins too much in every other gear
Nice numbers and Dave's right, boost oWNZ j00!
Old Apr 12, 2002 | 06:00 AM
orca's Avatar
Default Re: my dyno numbers, Hell yeah!!!!!!! (FL n NC rock j00)
Holy shiiittt
Was it 342 hp or 342 ps?
I'm intrestet for the 1/4 mile time, i think 18th may you kick *** in vienna
Old Apr 12, 2002 | 06:03 AM
Default Re: my dyno numbers, Hell yeah!!!!!!! (orca)
Too bad that the track in Vienna is not 1/4 mile, cause the area is too short, it is only 330 meters or so.
Old Apr 12, 2002 | 06:04 AM
MPH's Avatar
MPH
New User
That is niiiicccccccee
Old Apr 12, 2002 | 06:09 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Nice!
Old Apr 12, 2002 | 06:33 AM
PM-Performance's Avatar
Default Re: my dyno numbers, Hell yeah!!!!!!! (newt2)
damn that is sick as shitt. . . . . boost rocks , hopefully il be there soon .
Old Apr 12, 2002 | 06:39 AM
Are those corrected (ECE) values?
Old Apr 12, 2002 | 06:43 AM
YelLowITR's Avatar
well.. i think most of ppl know about you already, but can you tell me wat's your mods???? that's a good number man!!!
Old Apr 12, 2002 | 06:45 AM
Dr Pooface's Avatar
Default Re: my dyno numbers, Hell yeah!!!!!!! (YelLowITR)
LOL! 260+ kph here you come!
Old Apr 12, 2002 | 06:46 AM
hungsteR's Avatar
Nicey nice. Damn, boost oWNZ j00 forealz!
Old Apr 12, 2002 | 06:53 AM
Default Re: my dyno numbers, Hell yeah!!!!!!! (hungsteR)
yea what mods. ?
Old Apr 12, 2002 | 07:07 AM
Default Re: my dyno numbers, Hell yeah!!!!!!! (itr206)
Turbonetics T04e/T3 hybrid, .54 trim, stage 3 Turbine .63 trim
Greddy type-S Blowoff valve
Tial 35mm Wastegate (closed loop)
RC 440cc Injectors
Skunk2 adjustabel cam gears
AEM fuel press regulator (3.5 Bar fixed fuel press)
Walbro JR-fuel pump
Crower valve springs + titan retainers
JE pro-series pistons
Eagle rods
ARP head stuts
Jackson Racing 70° thermostat (coming soon)
Thermal R&D 3 inch exhaust
Catech 3" cat
3" mid pipe resonator
Haltech E6K ECU
GM 3 Bar MAP Sensor
"easy to use" valve for adjusting boost inside the cockpit
Clutchnet stage 2 clutch (perhaps it goes out and will be replaced with a costum SACHS clutch)
Fidanza flywheel (goes out)
17row oil cooler with thermostat
NGK copper plugs heat range 7
Castrol Formula RS 10W-60 oil
Aluminium flywheel sucks (on this hp) and this one is too light IMO.
EDIT: those are corrected DIN numbers. I have the USDM final drive at home and when I install it in combo with my stock JDM 5th gear and my 225/45/16 tires (diameter 615mm) + the redline of 9000rpm............please calculate it here: 4.400 fd and 5th 0.787. http://www.osella.com.au/java-gear-ratios-3.htm
299.6 kph here I come!
Should I do it?!?!?!?
[Modified by austrian type-R, 5:14 PM 4/12/2002]
Old Apr 12, 2002 | 07:15 AM
sackdz's Avatar
Damn, I'm gonna miss the event there by a couple days I think, doh!
I will try, but I think I'm leaving Austria on the 17th
Old Apr 12, 2002 | 07:49 AM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: my dyno numbers, Hell yeah!!!!!!! (sackdz)
pics for your car are requested!! Nicey nice #s
Old Apr 12, 2002 | 08:09 AM
Default Re: my dyno numbers, Hell yeah!!!!!!! (RealTypeR)
Thanks guys for your statements.
Pics of my car (old setup, waiting for WW bodykit) are at webshots. Follow the link in my sign.
Old Apr 12, 2002 | 08:19 AM
sgT's Avatar
sgT
Seems like some tuning is in order. numbers seem a bit on the low side....
unless DIN comes out lower than SAE
Old Apr 12, 2002 | 08:32 AM
Default Re: my dyno numbers, Hell yeah!!!!!!! (sgT)
yep, like I said we have to tune the ignition table and the cam gears. Also we don´t reved the **** out of it this time.
Old Apr 12, 2002 | 09:01 AM
CHEETAH's Avatar
very impressive even rubbing on dyno drums ... !!!
Greg
Old Apr 12, 2002 | 09:05 AM
mikeSONICGSR's Avatar
Nice!
Old Apr 12, 2002 | 12:52 PM
Jmm0056's Avatar
Default Re: my dyno numbers, Hell yeah!!!!!!! (mikeSONICGSR)
nice numbers
Old Apr 12, 2002 | 01:23 PM
TodaSi's Avatar
Sweet #'s! I wouldn't suggest running the dyno in 5th though....too long a gear.
Vienna? Think I might be coming out there in May. I have a friend who lives in Bratislava. May even try to hit up the Austrian GP, it's on the 12th yes?
[Modified by TodaSi, 5:24 PM 4/12/2002]
Old Apr 13, 2002 | 05:59 AM
Default Re: my dyno numbers, Hell yeah!!!!!!! (TodaSi)
on 18-20th May is the biggest Honda meet in Austria. Email me when you are in Austria for a meet!
95exdsmkilla
Aug 20, 2013 03:18 AM
Curt941
Jul 10, 2007 03:25 AM
Curt941
May 14, 2007 02:21 PM
555R
Jan 10, 2005 08:45 AM
GDM Z28
May 24, 2004 04:57 AM
