4G hatch with 5G SI motor and 2G teg tranny...will it work?
Old Apr 12, 2002 | 05:21 AM
BlowOff's Avatar
New User
Default 4G hatch with 5G SI motor and 2G teg tranny...will it work?
Will this setup work and bolt right in or will I have to get new axles? I am putting in a 5 gen Civic Si motor into a 4 gen Civic hatch. I know I can use the 4G tranny, but it only has 4 gears. If I bolt on a 2 gen Integra tranny however I get better gearing and 5 speeds, but was wondering if I have to modify the axles or use first gen Integra axles????? Any help would be appreciated.
Old Apr 12, 2002 | 05:28 AM
B18b Turbo's Avatar
New User
Default Re: 4G hatch with 5G SI motor and 2G teg tranny...will it work? (BlowOff)
no your an idiot a dohc tranny will not work on a sohc motor get a cable si sohc tranny
Old Apr 12, 2002 | 05:33 AM
BlowOff's Avatar
New User
Default Re: 4G hatch with 5G SI motor and 2G teg tranny...will it work? (HYBRID EG6)
Just wondering???? Can't you change the bell housing to make it work?
Stick with the 5 gen Si motor/4 gen Si tranny. Cool.
What axles?
[Modified by BlowOff, 2:42 PM 4/12/2002]
Old Apr 12, 2002 | 08:29 AM
meept's Avatar
Since the bell housing is also half of the transmission case, the answer is no. Try a B16 swap instead.
Old Apr 12, 2002 | 08:50 AM
BlowOff's Avatar
New User
Default Re: 4G hatch with 5G SI motor and 2G teg tranny...will it work? (meept)
OK so I am an idiot.
Here is what I got! 5 gen civic Si complete motor and cable si CRX tranny for $400
What axles do I use?
Old Apr 12, 2002 | 10:24 AM
ATS*VEEE's Avatar
get 4thgen Si axles, do not use DX or HF's they have smaller splines
Old Apr 12, 2002 | 10:44 AM
BlowOff's Avatar
New User
Default Re: 4G hatch with 5G SI motor and 2G teg tranny...will it work? (richierich)
Thanks for all the help everyone.
Old Apr 12, 2002 | 11:33 AM
Kamin's Avatar
your an *******
everyone starts somwhere dont assume they know as much as you all mighty one
LurkerS8
17
Jun 25, 2005 07:46 AM
gutted-dx
Mar 4, 2005 10:04 AM
KevronsEG
Jul 30, 2003 06:30 AM
Blaze45
Nov 30, 2002 08:00 AM
JStone2775
Aug 20, 2002 11:16 AM
