Bottom End Build
Old May 19, 2006 | 12:25 AM
itr1236's Avatar
Default Bottom End Build
So, tonight I took care of all of the clearances for the main bearings on my ITR bottom end. My question is when is the best time to plastigauge the rod bearings. It seems as though the block gurdle would be in the way for number 2 and 3 if I were to fully install the crank..... Can anyone let me know the best way to do this??
Old May 19, 2006 | 03:24 AM
Dave_B's Avatar
Not that I'm doubting your abilities, but I just had a car come into the shop...
Whoever built the engine forgot the thrust washer/bearings.
Make sure you check and double check with you check your clearences.
Old May 19, 2006 | 03:41 AM
D's Avatar
D
Default Re: Bottom End Build (itr1236)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1236 &raquo;</TD></TR><TR><TD CLASS="quote">It seems as though the block gurdle would be in the way for number 2 and 3 if I were to fully install the crank..... </TD></TR></TABLE>
well..... if the girdle is in the way..... why don't you get it out of the way.
The real reality, is that plastigauge is fairly useless. It will tell you if you are grossly over/under sized, but not anywhere near as equivalent as when it left the factory. If you clearances are that important to you... either buy the correct tools ($$$), or fnd a trustworthy machine shop.
Old May 19, 2006 | 07:46 AM
itr1236's Avatar
Default Re: Bottom End Build (D)
I replaced the main bearings by going with the code stamped on the block and the crank, so those ended up being the same bearing colors that the block originally came with. I checked those twice and they are within spec, and I did put the thrust washer in correctly.
I guess my concern was if there would be any negative effects from just unbolting the gurdle because of the sequence of loosening each bolt a 1/3 of a turn in a certain order. I'm guessing that it would have been easier to install the pistons first.
singlecamsaint
May 18, 2012 05:18 AM
revolt_allmotor
16
Aug 27, 2006 06:30 AM
brokenojoke
Dec 22, 2005 09:25 AM
crxhf19
May 21, 2005 04:56 PM
im sabah
May 12, 2004 07:08 PM
