Rear Brake Rotor Removal Help
Old May 18, 2006 | 08:56 PM
ProjektR's Avatar
Default Rear Brake Rotor Removal Help
Ok I just got done drilling off those 2 damn stripped screws and removed the caliper from the rotor. Now I'm having problems removing the rotor. Is there something I'm forgetting? Any help appreciated.
-Trung
P.S. I tried searching and all I got was problems with stripped screws
Old May 18, 2006 | 09:13 PM
SYTFU Tommy.'s Avatar
Default Re: Rear Brake Rotor Removal Help (ProjektR)
try tapping the rotor with a hammer if you are goign to resurface it. if you are planning to replace it, just use a BFH!
Old May 18, 2006 | 09:17 PM
JjuuN R's Avatar
Default Re: Rear Brake Rotor Removal Help (tngay)
a rubber mallot would be more preferable, just have to force things sometimes
Old May 18, 2006 | 09:34 PM
PrinceAli132's Avatar
Default Re: Rear Brake Rotor Removal Help (JUN.R)
As the others have said just tap it a few times with a hammer while turning/spinning the rotor to loosen it up.
Ali
Old May 18, 2006 | 11:41 PM
ProjektR's Avatar
Default Re: Rear Brake Rotor Removal Help (PrinceAli132)
yea. earlier I was wacking at it like crazy and no avail... stopped came on here posted and finished this episode of Overhaulin then went back to wacking and it finally came loose. guess that episode of Overhaulin helped Thanks for the help again guys! HT to the rescue!
Old May 19, 2006 | 10:48 AM
IN VTEC's Avatar
There are threaded holes for you use to use a M8 or M10x1.25 bolt to wedge the rotor off of the hub.
Before you reinstall the new rotor, you're supposed to deburr the face of the hub so that the rotor sits square on the hub. It's a standard brake job procedure.
Old May 19, 2006 | 10:54 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
You can stick two bolts into the other holes and slowly work it off.
Old May 19, 2006 | 12:17 PM
Batoutahell's Avatar
Default Re: Rear Brake Rotor Removal Help (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">There are threaded holes for you use to use a M8 or M10x1.25 bolt to wedge the rotor off of the hub.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">You can stick two bolts into the other holes and slowly work it off.</TD></TR></TABLE>
Even better, there are 2 threaded holes in the rotor, just thread two bolts into the holes and wedge the rotor off the hub.
Integra4lyfe069
Apr 11, 2009 06:43 AM
thtguybryan
Dec 27, 2007 11:03 PM
a1320addict
Jan 17, 2006 10:16 PM
blkgsr03
13
Sep 14, 2005 11:15 AM
Regular Series
Aug 15, 2004 08:04 AM
