heater controls quit working?!?!?!
so recently i was drivin and noticed my heat wasnt on, altho the switch was on number 2. it was working fine an hour ago.... it just randomly doesnt work anymore. the lights dont even light up to show that its on... i checked all the fuses, searched here for hours and still found nothing. id greatly appreciate the help. and the car is a 92 Civic SI hatch with a JDM B16. but like i said everything worked fine before
huh. If the fan alone doesn't work on some speeds then it is the resistor. It is located inside the heating "air box" underneath the dash. Pull the two phillip screws and check to see if the filaments are intact. If all the speeds don't work then it could be the blower motor or resistor as well. Lastly, it could be your heating control unit that gave up. Good luck.
so last night i went to check behind the cd player and i pulled it out, everything looked normal. altho now my cd player quit working, and my clock goes to 1:00 every time i start the car adn its kind of fading. so i think some wires may have been pulled loose when i took the antenna out? could that be the problem?
dondotta
Aug 7, 2006 09:27 PM
