vibration from the front
Old May 18, 2006 | 05:12 PM
Panda Z33's Avatar
Default vibration from the front
when i use my front brakes i get some vibration. at first i thought i was some rotors but my service guy said rotors look fine. he thinks it because my tires are almost bald. anyone have this experience? im changing my tire tomarrow. hopefully thats the fix
Old May 18, 2006 | 06:40 PM
ngng's Avatar
Default Re: vibration from the front (Panda Z33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Panda Z33 &raquo;</TD></TR><TR><TD CLASS="quote">when i use my front brakes i get some vibration. at first i thought i was some rotors but my service guy said rotors look fine. he thinks it because my tires are almost bald. anyone have this experience? im changing my tire tomarrow. hopefully thats the fix</TD></TR></TABLE>
how would the service guy know the rotors are find without removing them or taking measurements? it could be a wheel balance issue, but you would get vibration even when you werent braking
Old Aug 31, 2006 | 09:50 AM
gsregcoupe82's Avatar
if you feel vibration in the brake pedal or only when braking it's definately a rotor issue.. the service guy can't look at the rotors and say they're fine... the only way to tell is to take measurements or just have them re-surfaced..... I've had this problem on 2 different cars and both times re-surfacing the front rotors fixed the problem.. you can't tell just by looking at it cuz you can't see rotor warpage.. they always look smooth
Old Aug 31, 2006 | 11:28 AM
Etylorcen's Avatar
Default Re: vibration from the front (gsregcoupe82)
If your tires are bald you should be changing them anyhow. Update us after you changed the tire.
Old Aug 31, 2006 | 11:55 AM
MSchu's Avatar
My Name is Nobody
shoot, change both the tire and brakes.
Old Aug 31, 2006 | 02:54 PM
marmaladedad's Avatar
Default Re: vibration from the front (MSchu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MSchu &raquo;</TD></TR><TR><TD CLASS="quote">shoot, change both the tire and brakes.</TD></TR></TABLE>
Prrrrrus One!
New (to you) bike? I always change out the tires and brake pads when I purchase a motorcycle. If that solves the issue, hooooray!
JDMproblem
17
Apr 6, 2007 04:26 PM
dcb284
May 19, 2005 06:51 AM
devilpuppy
Jul 21, 2004 08:01 PM
gsr-2nr
Apr 29, 2004 01:33 PM
PetroGuyX
May 12, 2003 07:29 AM
