Exhaust piping Question Pls help!!!!
B A N N E D
From: Orange County / Palm Springs 714/76hoe, ca, usa
hey wasup guys well let get to the point im planning on changing my exhaust (2.5)piping to 3inch after the down pipe straight under the fuel tank slanted to the back u get what im saying.
here my question?????
would the hp and tq increase by doing this ?
do i need to go to the dyno to retuned again (im tuned on 2.5 inch piping)?
thanks in advance
thanks in advance
B A N N E D
I KNOW BUT ILL RAISE THE REAR UP ALIL BIT ( IM ONLY GONNA USE IT FOR DRAG RACE)
UP FOR SOME INPUT
UP FOR SOME INPUT
B A N N E D
yup maybe ill just go to the oem route
but i really need an input if hp tq will increase ??
and or if i need to tune again ??
thanks
thanks
B A N N E D
So its not gonna make any difference
How come though I thought 3 inch pipe will increase hptq
3" will increase power yes, but going straight back under the tank isn't going to make much difference instead of just putting it where the stock systems goes. Oh and yes, you will need to check your tune when changing your exhaust like that.
B A N N E D
Ahhhhhh man so if I need to tune I again ill just redo my dp to 3 inch aswell and turn up the boost (I'm only boosting 7psi right now)ill try to push it at 10psi thanks for the input
If anyone wanna add somemore details that would be great thanksss
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon95eg »</TD></TR><TR><TD CLASS="quote">Ahhhhhh man so if I need to tune I again ill just redo my dp to 3 inch aswell and turn up the boost (I'm only boosting 7psi right now)ill try to push it at 10psi thanks for the input
You're going to do that while at the tuner, and not just do it/not check the tune right?
</TD></TR></TABLE>You're going to do that while at the tuner, and not just do it/not check the tune right?
JDMCRX
Welding / Fabrication
12
Jan 27, 2009 07:42 PM
Fallen86
10
Jan 7, 2006 02:19 AM
urquidezj
69
Sep 28, 2004 02:25 PM
T-RO
Oct 17, 2003 08:05 AM
silverEH2
Apr 7, 2003 08:47 AM
