whining/whistling problem very annoying help plz?
Old May 18, 2006 | 04:52 PM
2slowCivic's Avatar
Default whining/whistling problem very annoying help plz?
ok ive read a couple other posts that seemed similar but didnt fit my description exactly so my problem is i have a high pitch whine which at first i thought was a belt noise until i opened the hood and the noise was coming from the other side of the engine away from the belts. i listened by the intake and i swear it sounded as though it was coming from the tranny but im not exactly sure.
btw. its a 91 lx with f22b dohc nonvtec swap if that matters
it also has short ram intake but i swear its from the trans.
Old May 18, 2006 | 05:02 PM
hondadude's Avatar
Default Re: whining/whistling problem very annoying help plz? (2slowCivic)
grab a long screwdriver and use it as a stethoscope, try listening to the Dist for bearing noise as well
Old May 18, 2006 | 05:04 PM
2slowCivic's Avatar
Default Re: whining/whistling problem very annoying help plz? (hondadude)
ok thank you ill do that tomorrow all my tools are at work
Old May 19, 2006 | 04:41 PM
2slowCivic's Avatar
well figured out the problem me and a guy at work used his stethescope and it turns out it is from the trans, when i push down the clutch noise goes away we easily decided its the throwout bearing thanks for the help
_RedRiceR_
Jun 19, 2006 12:59 AM
redpeppers
12
May 18, 2006 12:49 PM
slowpokecivic
Sep 30, 2005 01:59 AM
DeDonDeRosa
Aug 1, 2002 08:20 PM
