coilover installation problem
right now i took off the old spring and i want to put the coilovers on, but the coilover sleeve and the shock cover thing will collide, do you know where all the washers go? and the rubber thing circled wont let the bolt on the shock come up all the way so we could put the nut on.. help needed ASAP. thanks
Modified by Zeductive at 4:18 PM 5/18/2006
you cant use the dust boots (shock covers) with adjustable sleeves. youll be fine without them.
you need to reuse EVERYTHING else from the old shock. especially the goldish tapered washer.
you can swap the inside rubber grommet under the top hat with the red grommet you circled if you want. put it under the top hat.
if you really wanted to do yourself a favor, ditch the whole kit. but thats another story.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">
if you really wanted to do yourself a favor, ditch the whole kit. but thats another story.</TD></TR></TABLE>
