Fuel Pump
Old May 18, 2006 | 01:20 PM
Girl's Avatar
Default Fuel Pump
I got a 90 Civic Lx. And for some reason it won't start. It cranks and everything, but it just won't start up. I noticed that I can't smell and fuel so I'm guessing the fuel pump is broken or something... Unless someone else has any other suggestions.
But I was wondering what fuel pump this kind of civic uses. And does it use the same fuel pump as a 98 Integra Type R? If it does, I can just take if off my busted ITR and throw it in there for the time being. But any kind of suggestion or responses would help me out. Thanks.
Old May 18, 2006 | 01:50 PM
yellowrexsi's Avatar
Default Re: Fuel Pump (Girl)
Its probably the main relay. If you search, you will probably found 10,000 posts about this
Old May 18, 2006 | 02:24 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: Fuel Pump (yellowrexsi)
http://www.4gcivic.net/wp/mainrelay.html
http://honda.hybrids.jp/tech/p...shtml
Good troubleshooting tips:
http://autorepair.about.com/cs...a.htm
beware of pop-ups..
Old May 18, 2006 | 05:18 PM
Girl's Avatar
Took out the main relay, checked it. Looked good.
When I turn the key to AC II, I can hear a noise, which I'm thinkin is the Fuel Pump. So I'm not sure what's wrong really. Will it still make the noise if the pump is broken?
AZ accord
Sep 10, 2015 03:24 PM
hatchBK4life
Aug 2, 2010 05:11 PM
4doorcivic9
Jun 11, 2008 06:31 AM
