B16a2-----b18c1/c5
ok.. i have a b16a2 with b16b pistons an b16b head and b16b trans.... can i pu t a b18b1 b18c1 or b19c5 crank in it to make it a 1.8L and more like a c1/c5
u can not make it into a 1.8 without swapin a b18c5 block, or a b20 block to make it a 2.0.. but along with either one of these blocks you need blocks original crank as well
hope that helps.. i have a b16a2 with ctr cams.. i want to swap the block with a b20 block or a 18c5 block ... dont know which to do!
EG shell, JDM b16a w/CTR cams & t/b adds signifigantly more power, 10-15 more HP than stock GSR. . . but still about 10-15 less LBS/TQ
and thats stock no intake or exaust on my B16A. . .
JDM B16a 170HP
JDM B16b 185HP
JDM B16a 170HP
JDM B16b 185HP
b18's are off da hook, but b16's are nothing to scoff at. . . im thinking next a thin B16b head gasket to bump compression 10.4(stock b16a) to 10.6. . . as a fully stock b16b has 10.8c/r, but i dont have the pistons
. . . as for the CTR heads, they,re basically the sme except for the wilder cam and the stronger retainers for the valve train. . .
i have a b16a2.. i wanna stick a b20 in it.. somebody told me it be better then 18c5... do i have to do any other mods to this block? like the oil squirts and stuff? can i put ctr pistons into this b20 block?
you can but you need custom built rods if you want to do something like this.
Just get a gsr block or do the ls vtec and you should be able to run your ctr piston with this any of this engines.
CTR(higher compression) & B16a pistons are 81.5mm
CR-V pistons are 84mm. . . the b20 also has a longer stroke for more TQ since they have 4 wheel drive. . . the CR-V(B20 first gen CR-V) has really good potential as a turbo engine but otherwise the B18c5 is WAY better. . . its a Type-R performance engine
compared to the B20 which is a "small truck" engine.
compression for the B20(first gen CR-V) by the way is 8.8, which is why its good mostly for turbo
second gen CR-V has about 9.6c/r
Modified by dheadcivic at 3:09 PM 5/18/2006
Modified by dheadcivic at 3:12 PM 5/18/2006
older, late 80's prelude b20 engines are the odd ball of the group because their parts arnt really interchangeable w/the rest of the "B-series" family. . . its an unusually tall engine. . . mounts are harder to get there may be scraping issues depending on the shell it's being swapped into. . . B20 w/b16 head equals lots of potential. . .
Modified by dheadcivic at 3:07 PM 5/18/2006
Modified by dheadcivic at 3:10 PM 5/18/2006
Modified by dheadcivic at 3:30 PM 5/18/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dheadcivic »</TD></TR><TR><TD CLASS="quote">b20 CR-V engines are the odd ball of the group because their parts arnt really interchangeable w/the rest of the "B-series" family(older b20's). . . its an unusually tall engine. . . mounts are harder to get there may be scraping issues depending on the shell it's being swapped into. . . B20 w/b16 head equals lots of potential. . .
Modified by dheadcivic at 3:07 PM 5/18/2006</TD></TR></TABLE>
Totally wrong.
The b20 has the same external demesions as a LS. Its basically an 84mm LS motor. Lots of parts are interchangeable with other B series.
Also there is a company(cant remember which) that makes special pistons so you can use LS crank and rods to stroke your b16.
Totally wrong.
i changed it, youre right i meant the older B20's from the preludes late 80's engine
the modern B20(CR-V) is just like you said an LS w/84mm pistons. . .
wouldnt it make more sense to just put a B16 head on an LS or a B20 for that matter??
i'll dig up some info on the crank. . .
Modified by dheadcivic at 3:48 PM 5/18/2006
