need help with codes PLEASE.
Old May 18, 2006 | 12:05 PM
CIVIC96DXcp's Avatar
Default need help with codes PLEASE.
my car is throwing 2 codes. i checked today and the codes were
1336 and 1337
all i know is that they are interelated. anybody can help me on this? what should i fix to get rid of the code. i know it's about sensor and that there is no power going through this sensor. someone please enlighten me
thanks
my car is 96 civic DX. d16y7
Old May 18, 2006 | 12:20 PM
alleyezonme's Avatar
Default Re: need help with codes PLEASE. (CIVIC96DXcp)
P1336 Engine Speed (RPM) Fluctuation Sensor Intermittent Interruption
P1337 Engine Speed (RPM) Fluctuation Sensor No Signal
I don't really know OBDII cars, but i would say you need a new Crankshaft speed sensor. First check the wiring to make sure no wire is disconnected or shorting out or anything. It should be located near your crankshaft pulley.
Old May 18, 2006 | 01:05 PM
thanks man. i will check into it
ps: is this the kind of things where you can do it yourself??
thanks anyway
Old May 18, 2006 | 01:08 PM
1.8turbolsvtec's Avatar
Default Re: (CIVIC96DXcp)
look at the bracket that goes from the bottom of the intake manifold to the block the harness rubs on it and shorts it is a tsb
Old May 20, 2006 | 02:38 PM
Default Re: (1.8turbolsvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8turbolsvtec &raquo;</TD></TR><TR><TD CLASS="quote">look at the bracket that goes from the bottom of the intake manifold to the block the harness rubs on it and shorts it is a tsb</TD></TR></TABLE>
if it shorts it, what should i do? cut the wire and connect a new one? or should i just buy a new sensor?
Old May 20, 2006 | 02:44 PM
Archidictus's Avatar
Unceasing Measure
Lengthen and reroute the wire(s).
Old May 20, 2006 | 02:56 PM
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Lengthen and reroute the wire(s).</TD></TR></TABLE>
it order to do this, i need to strip and re connect the wire right? thanks for the help.
Old May 20, 2006 | 03:55 PM
axtran's Avatar
code 1337? your car is Leet. leave it be. TOO COOL 2 DRIVE.
Old May 20, 2006 | 04:31 PM
Unceasing Measure
Default Re: (axtran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by axtran &raquo;</TD></TR><TR><TD CLASS="quote">code 1337? your car is Leet. leave it be. TOO COOL 2 DRIVE.</TD></TR></TABLE>
This isn't World of Warcraft, sweety. It doesn't matter how many orcs and dragons you kill with your +4 Honda of nature death reaver 'leetness if you don't know how fast you're going.
Kris's turbo
Jul 11, 2011 12:59 PM
jdm21
May 3, 2009 12:09 PM
hondaracing1
Nov 27, 2004 08:59 AM
ej6g
Dec 10, 2003 02:00 PM
