H22 Swap: OBD 2 to OBD 1
Old May 18, 2006 | 11:45 AM
Iamcuddles's Avatar
Default H22 Swap: OBD 2 to OBD 1
So I have a 01 Prelude SH OBD 2b engine, transmission and ECU. Im going to be buying a 90 Accord pretty soon. Ive been reading about how all these swaps are going to OBD 1, and changing distrubutor, cap, injectors and other things to make the engine OBD 1. Would it just be easier to stay OBD 2b in the Accord, since I have everything already? Or do I need to get more money and buy a new/old ECU and go from there? Thanks.
Old May 18, 2006 | 02:21 PM
Slopoke's Avatar
Default Re: H22 Swap: OBD 2 to OBD 1 (Iamcuddles)
The obd2B ecu has an immobilizer, which reads a code from the ignition key, before it will allow the car to start. You will need to bypass that inorder to use the '01 ecu.
If you want to convert to obd1, you only need to swap out the injectors for obd2A or obd1 injectors, because honda changed the size of them in like '99. Up till then, they were all the same size. So if your using an older ecu, you need to use the older injectors.
You can use the '01 distributor, alternator, etc, etc.
Old May 19, 2006 | 07:49 AM
Iamcuddles's Avatar
Default Re: H22 Swap: OBD 2 to OBD 1 (Slopoke)
So thats the only thing I will need to do? All the wiring for tach and stuff just pin it up to the right thing on the ECU and that will save me a lot of wiring.
Is there anyway I can move the complete mobilizer setup to the Accord?
Old May 19, 2006 | 09:19 AM
Slopoke's Avatar
You would need the whole ignition switch assembly and ignition key from the prelude.
Im not sure what else, since I usually just swap to obd1.
Old May 19, 2006 | 12:34 PM
Iamcuddles's Avatar
It would be cool though to have a Prelude key for an Accord
So thats it, as far as putting the OBD2 ECU in a OBD1 car, eh?
91HCRX
Jan 10, 2012 09:35 AM
cnydc2
Aug 7, 2008 02:30 PM
honcrx91si
Aug 8, 2005 09:34 PM
uncle
May 28, 2004 09:28 AM
comptechgsr2000
Apr 25, 2002 05:19 AM
