stupid question
Old May 18, 2006 | 10:23 AM
Suck my DX's Avatar
Default stupid question
will copper spraying my hg lower my compression?
the reason i ask this is cuz people say to apply it generously on each side...im removing a layer of my hg to get to the right CR for these cams and i wanna get every lil bit of compression out of it.
if the head has been freshly resurfaced is there even a need to copper spray the hg?
Old May 18, 2006 | 10:31 AM
( o )( o )'s Avatar
Default Re: stupid question (Suck my DX)
some people swear by the copper spray, some people think it's crap.
i personally don't see a need for it if the head surface and block deck are both straight and everything is torqued down properly.
couldn't tell you about the compression though - if it is sprayed liberally enough, it could increase the thickness.
Old May 21, 2006 | 04:26 AM
thahuhstunna's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">will copper spraying my hg lower my compression?
if the head has been freshly resurfaced is there even a need to copper spray the hg?</TD></TR></TABLE>
^ no
Old May 22, 2006 | 12:29 AM
Suck my DX's Avatar
Default Re: stupid question (thahuhstunna)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thahuhstunna &raquo;</TD></TR><TR><TD CLASS="quote">
^ no</TD></TR></TABLE>
and why is that?
Old May 22, 2006 | 12:46 AM
thevanitygroup's Avatar
I wouldnt use it. Remove a layer, make sure everything is to spec and put it together. You should have no problems.
Old May 22, 2006 | 01:12 AM
Suck my DX's Avatar
Default Re: stupid question (thevanitygroup)
now heres where i always get mixed answers...does it matter which layers i use?
like top/middle...top/bottom...middle/bottom...or is it all the same?
Old May 22, 2006 | 04:19 AM
black_EM1's Avatar
Community Builder
Community Influencer
Top and bottom. I don't quite remember why, though. I'll get back to you on that
Techna600f4i
Jun 19, 2006 11:49 PM
sportyaccordy
25
Jun 12, 2006 10:23 AM
kidd_drastic
16
Apr 8, 2006 09:11 AM
ITR_1211
Jan 18, 2004 08:09 AM
Notaverage
Dec 1, 2003 04:53 PM
