crimps and crimp tool oem uses?
Old May 18, 2006 | 09:55 AM
gldndrgn14's Avatar
Default crimps and crimp tool oem uses?
I was wondering if anybody knew what type of crimps the oem companies like honda and toyota uses. I need to redo some of my wiring, and would like to use these instead of the ghetto 1s you can buy or even soldering. and also where i can get new plug pins at? which crimper is the correct tool for the pins and would it be the same as the crimps they use? i will try to get a pic up of the crimp when i get a chance. thanks
ok, i have pics up of the crimp, t, bridge, whatever you want to call it. sorry they are crappy pictures. i dont have a digi with me, just my phone. but this gives you an idea.
oh and i have a link for weather pak terminal kits, but i doubt these will work for our pins. but are the crimpers the same?
https://www.casperselectronics...=conn
Modified by gldndrgn14 at 7:20 PM 5/18/2006
Modified by gldndrgn14 at 7:21 PM 5/18/2006
Modified by gldndrgn14 at 2:27 PM 5/18/2006
Modified by gldndrgn14 at 2:28 PM 5/18/2006
Old May 18, 2006 | 12:27 PM
Trooper's Avatar
Default Re: crimps and crimp tool oem uses? (gldndrgn14)
That crip style is called a "W" crimp. Those crimper tools can be found retty cheep at your local swap meet.
Now for the ECU pins to the best of my knowledge the crimp style is a "open barrel"
Old May 18, 2006 | 02:47 PM
gldndrgn14's Avatar
Default Re: crimps and crimp tool oem uses? (Trooper)
thanks man. that helps a lot. also, would all the other pins that go into other plugs also be open barrel?
would this work if i just cut off the rings?
i cant seem to find these at all. oh and i have better pics of it.
if anybody knows the technical term it would be very helpful. i found the crimpers but not the crimps.
Modified by gldndrgn14 at 12:35 AM 5/19/2006
Old May 18, 2006 | 03:39 PM
tony1's Avatar
I have the Honda sensor female pins and boots in stock if anyone needs any.
Old May 19, 2006 | 07:15 AM
Trooper's Avatar
Default Re: crimps and crimp tool oem uses? (tony1)
Here is some good new's for all of us honda guys. Napa sells that tool #726603
here is a link with some information on the tool look at the 9th bost down.
http://www.letstalksnow.com/fo...=5773
Old May 19, 2006 | 07:47 AM
bigTom's Avatar
open barrel and "w" splice are pretty much the same thing. at least every differant one i have ever seen and done looks and crimps the same!
what you are looking for is called a splice. and they are readily available in differant forms; (with or w/o insulation, heat shrink, etc...)
here is the type of tools you should be looking for
http://www.weatherpack.com/pages/900558/index.htm
if all you are looking to do is splice 1 wire into 2 or to extend wires... a normal sealed splice you can pick up at your local radio shack will be more than sufficient. if u plan on doing some more, open barrel splices and some dr-25 is the way to go!
if you want to do really small open barrel terminal like on the honda harness you need to find a crimper with a really small jaw... local radio shack should have a BS "lemo crimper" to help you out.
(if you only need a couple, pm me and ill see what i can do for you. i stock alot of small electrical pins/"accesories.")
Old May 22, 2006 | 02:48 PM
gldndrgn14's Avatar
Default Re: crimps and crimp tool oem uses? (bigTom)
i dont like those that i can pick up at most local stores. i hate them. the are too bulky and break a lot if moved a lot. id prefer this type because it is more secure and takes up a lot less space than that and soldering. so i would guess this is a bare splice. thanks.
Old May 22, 2006 | 05:53 PM
TrueNorthStar's Avatar
I get thoes from http://www.p-r-s.com/.
They have them listed as "Term Splice xx GA" (xx = 22, 18, 14 or 12 depending on gauge)
Just give them a call.
Old May 22, 2006 | 06:19 PM
Default Re: crimps and crimp tool oem uses? (TrueNorthStar)
Here is a pic of what I get from P-R-S.com:
Here are some of the tools I use... for most of the "Terminal Splices" I use the tool that says "SERVICE TOOL I" on the handle. :
Old May 22, 2006 | 06:46 PM
HiProfile's Avatar
I guess I never thought of using stuff like this. I've been just soldering ends together since my R/C car days - wiring 3-4 wires to another gets frustrating. I'd still say add some solder, I've never trusted unsoldered connections.
Old May 22, 2006 | 09:40 PM
Trooper's Avatar
Default Re: crimps and crimp tool oem uses? (HiProfile)
The DMC crimpers are very nice, my dad borrowed a few pairs from work when i was a kid. Recently i was going through his tools and found them, dad hooked me up with some other nice stuff also
Old May 25, 2006 | 10:42 AM
gldndrgn14's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrueNorthStar &raquo;</TD></TR><TR><TD CLASS="quote">I get thoes from http://www.p-r-s.com/.
Just give them a call.</TD></TR></TABLE>
haha thanks. yeah i called them after tony had referred me to them. thanks. i got those and some raychem heat shrink. hopefully i ordered enough. ahah
NCintegraLS
Honda Fit
Jan 12, 2009 08:42 AM
liquid:cooled
Suspension & Brakes
153
Jun 20, 2007 03:11 PM
jcoosi
Dec 4, 2005 02:32 PM
itr501
Aug 5, 2002 04:50 AM
