oil loss
I'm wondering if anyone else has this going on with their S2K. I notice that my car uses about a qt of oil every 3kmi. I've searched all over the motor for leaks, there are no drops or leaks on my garage floor or the driveway. The only thing I can think of is that she's burning it, although I've never seen any smoke even on start up. Is this normal or should I have it checked out? Thanks in advance....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverDc2-Ap1 »</TD></TR><TR><TD CLASS="quote">what type of oil are you running?</TD></TR></TABLE>
When I run M1 syn, I notice it burns about 1/2 - 1 qt every oil change (3k miles). I have run Castrol before (not on the S, but ITR), and noticed it didn't lose any at all.
i use to use Mobil1 Syn as well. I noticed that **** would burn off about 1/2 qt modereatly. I use the Mobil 10w-30 regular now (regular Honda oil) and its a little better.
<FONT COLOR="red">If you VTEC you must check!</FONT>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TL1000R »</TD></TR><TR><TD CLASS="quote"> although I've never seen any smoke even on start up. Is this normal or should I have it checked out? Thanks in advance....</TD></TR></TABLE>
if you see smoke during start up you have problems... unless you spill it during an oil fill then it will burn off the hot parts it touches, other then that you would really need to pray for a warranty.
since they havent created a 100% efficient engine yet, youre gonna burn off some hot fluids.
wessieball
Jul 6, 2006 04:15 PM
fullraceacura
Feb 1, 2005 07:24 PM
