short shifter
Old May 18, 2006 | 07:33 AM
jdmEF8racer's Avatar
Default short shifter
i got this short shiter for my 91 crx and i was jus wondering if i had to go under the car and disconnect the shift inkage from the shfiter to get it in or can i do it from inside the car if anyone has done this in there car can i get some guick advice.
::CR-VTec:: 91 Si CRX
Old May 18, 2006 | 07:45 AM
crxblues's Avatar
Default Re: short shifter (jdmEF8racer)
no
Old May 18, 2006 | 07:50 AM
Default Re: short shifter (crxblues)
no what? i dont have to go under or i can't do it from inside the car?
Old May 18, 2006 | 07:52 AM
thesmogman's Avatar
You go down now. But, seriously yes you have to go under the car. There are two 10mm bolts that you have to take off to drop the shifter out. When you do this regrease everything good this will give you a good feel from the shifter.
It is pretty easy should take you about 30min 1hr at most.
One gottcha the linkage rod has a 1/2" steel stock at the end of it. Check it for clearance on your exhaust. It took me 15min to cut it off with a hacksaw.
The reason you will have clearance problems is the new shifter drop's the linkage down about an inch.
Old May 18, 2006 | 07:54 AM
crxblues's Avatar
oh im sorry common sense would tell you that you have to go under the car to disconnect the hifter to the linkage.
Old May 18, 2006 | 08:51 AM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxblues &raquo;</TD></TR><TR><TD CLASS="quote">oh im sorry common sense would tell you that you have to go under the car to disconnect the hifter to the linkage.</TD></TR></TABLE>
He's probably just never looked at the shifter/linkage connection. (I'm assuming) Looking at it would easily answer your question.
Old May 18, 2006 | 09:54 AM
b18sihatch's Avatar
Default Re: short shifter (Autoworks)
since you are going to be under the car unbolting stuff and whatnot, i recomend replacing your shift bushings with energy shift stabalizers, they work wonders and if you already havent replaced the old worn out oem bushings this is the best time to do so, they arent that much and make alot of a difference
gameknb
Jun 11, 2005 07:32 AM
Gimpo
Dec 26, 2004 11:51 AM
mr_wasabi
Jul 12, 2004 03:12 PM
crxzc
Jul 2, 2002 05:09 AM
LD_EGSICK
Jun 25, 2002 12:31 PM
