dang indiglo gauge!
Old Apr 11, 2002 | 09:14 PM
LuderCriS's Avatar
Default dang indiglo gauge!
i recently installed indiglo gauge and it works fine, but when i floored my lude the tach stayed at 4 rpm 1-4 is fine but higher rpm is stuck! what do i do now!!!
Old Apr 11, 2002 | 09:18 PM
typeSwarrior's Avatar
Default Re: dang indiglo gauge! (chanluder)
I'm going to assume you f*cked with the needles or something, because I never had that problem.
Solution: Return to stock cluster --- You might have to have the dealer or something look at it if the needle is screwed though.
Old Apr 11, 2002 | 09:22 PM
LuderCriS's Avatar
Default Re: dang indiglo gauge! (typeSwarrior)
its just doesnt wanna go 5 up im gonna call the shop that installed them
Old Apr 11, 2002 | 09:28 PM
ELUD THS's Avatar
New User
you broke the needle. theres a series of wires behind the needle so if you move them around you mess the the needle.
Old Apr 11, 2002 | 09:31 PM
LuderCriS's Avatar
Default Re: dang indiglo gauge! (ELUD THS)
errr i paid them plus installation they better fix this sh*t
Old Apr 11, 2002 | 09:53 PM
ELUD THS's Avatar
New User
they should warrenty all there work, if its an accredited shop.
Old Apr 11, 2002 | 10:34 PM
If they give you any hassle or any kind of run-around, raise some hell dude. Get all up in there faces and be like--"I OWN you biatch, fix it now!"
Old Apr 12, 2002 | 06:01 AM
LuderCriS's Avatar
thatd be cool
Old Apr 12, 2002 | 08:23 AM
Smurfylude's Avatar
are you sure the needle isn't getting stuck on the indiglo's? See if the indiglo's are floating off the back ground. if they are get some thin double sided sticky tape and tape them down, should do the trick.
Old Apr 12, 2002 | 09:15 AM
prelude10's Avatar
Default Re: dang indiglo gauge! (Sushi X)
I had the same **** happen to my gauges. I bent the gauges when i put the in. I just got a new set a it worked fine.
Old Apr 12, 2002 | 10:02 AM
prelude1897's Avatar
Default Re: dang indiglo gauge! (prelude10)
If the shop fucked it up, then they have to replace it....
Old Apr 12, 2002 | 05:18 PM
LuderCriS's Avatar
Default Re: dang indiglo gauge! (prelude1897)
ok update! i just went to the shop and stayed there for HOURS err they fixed it but when i got in to my car the speedo is pointing at 150mph! went in again and they fixed it errrrr now i can go pass 4 and up but the thing is when i start the car the tach is still pointing at 0 so i have to rev it to make the tach pointer working. thats about it but starting is a biatch i have to rev first what ya guys think?
Old Apr 12, 2002 | 10:08 PM
ELUD THS's Avatar
New User
thats no good. if you have to rev first to start the car, thats no good /
Old Apr 13, 2002 | 12:16 AM
I think they are blowin smoke up your ***...tell em what's up
Old Apr 13, 2002 | 12:45 AM
LoudLude's Avatar
I am confused now.. The gauges should have nothing to do with how your car starts. When your car is running, the tach should read 400-800 rpm, if it doesnt do that, the needle is out of sync. It needs fixed. If you have to pump your gas before your car will actually start running, it is a whole different problem.
Old Apr 13, 2002 | 10:45 AM
LuderCriS's Avatar
Default Re: dang indiglo gauge! (LoudLude)
i know! sometimes when i start my car it reads sometimes it doesnt what do i do man?should i get different gauge at different shop?
95_DB7
Apr 29, 2013 08:23 AM
platinumx6
Oct 13, 2006 07:29 PM
puregold4
Jan 4, 2005 12:57 PM
ilovemydc2
Nov 18, 2004 10:04 AM
aznfab
Aug 26, 2003 03:13 AM
