Safe to drive with this check engine light?
Old May 17, 2006 | 09:30 PM
candy eg's Avatar
From: The Real O.C. Oakland Chinatown, California, USA
Default Safe to drive with this check engine light?
Well, my car has been finished, the swap is in. gsr with itr pistons, new rings, fresh hone, new bearings, stock gsr head. and it has been throwing this one code. Code #14, i believe it had something to do with the icav or something like that. I was wondering if it would be safe to drive the car with it on for a couple days, traveling about 40 miles each day. The car runs pretty good but when i let off the throttle it just sorta bogs. my friend already tried everything to his knowledge to try to fix it, and he knows a lot more than me, so imma just wait to the weekend to take it to a shop.
Old May 21, 2006 | 04:38 AM
thahuhstunna's Avatar
Default Re: Safe to drive with this check engine light? (candy eg)
it's fine, but dont expect your vtec to engage...still, try and fix it soon
Old May 21, 2006 | 10:04 AM
AL ASPIRATED's Avatar
Default Re: Safe to drive with this check engine light? (thahuhstunna)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thahuhstunna &raquo;</TD></TR><TR><TD CLASS="quote">it's fine, but dont expect your vtec to engage...still, try and fix it soon</TD></TR></TABLE>
youll be fine driving it like dat for awhile, honda is notorious with the IACV issues. you can try to clean it up or replace it. the only thing you may notice is a loss in gas mileage, depending if the IACV is stuck.
Old May 22, 2006 | 01:02 PM
50SaysHeEatsIt's Avatar
Default Re: Safe to drive with this check engine light? (AL ASPIRATED)
Pretty simple to clean...Two bolts on the back of the intake mani , Two coolant lines then its off. There is a screen on the left you will see it , they have a habit of getting clogged . Use alittle carb cleaner to clean it off and then put it back on.
Good luck
Old Jun 5, 2006 | 09:33 AM
HatchEh2's Avatar
Default Re: Safe to drive with this check engine light? (50SaysHeEatsIt)
its fine.. but not good...
you sure thats the only code your throwing? because theres quit a few sensors in that area that plug into one another... so for instance you could have the IACV plug plugged into the IAT or another sensor in that area... make sure that the plug coming outta the IACV has a yellow/black wire (positive) in it. if not... find the plug that does and plug that to the IACV. the IAT sensor should have the plug with a red/yellow wire.
(if this is the case, disconnect the neg. battery terminal for 3mins to reset your ecu and then check to see if you still have a CEL.) if not, replace your IACV.
but first try what my boy Andy (50SaysHeEatsIt) said, clean the screen.
good luck, hope that helped
Old Jun 5, 2006 | 11:07 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Safe to drive with this check engine light? (HatchEh2)
Unless you made a custom wire harness, there are only two plugs you can switch by mistake, and that the MAP and TPS sensors... and the car would run like *** if you did that.
Solid CEL = bad sensor, car will run ok until you fix it.
Flashing CEL = your lucky the car is still moving. Find a place to stop, now.
Old Jun 5, 2006 | 07:25 PM
redface's Avatar
u can pop can it....just get a coke can etc. and make a gasket with it blocking the iac off make sure u make holes in it for the bolts to go through this works but may idle a little low car will not high idle in open loop though
Old Jun 5, 2006 | 08:37 PM
HatchEh2's Avatar
Default Re: Safe to drive with this check engine light? (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">Unless you made a custom wire harness, there are only two plugs you can switch by mistake, and that the MAP and TPS sensors... and the car would run like *** if you did that.
Flashing CEL = your lucky the car is still moving. Find a place to stop, now.</TD></TR></TABLE>
every EG i had, had a few two pin plugs that where interchangable on the back of the IM.
i can remember i went thru hell to figure them out after swaping my first motor. Im almost positive the IAT and the IACV are like that. also the little plug coming outta the IM itself.
Old Jun 5, 2006 | 08:38 PM
HatchEh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redface &raquo;</TD></TR><TR><TD CLASS="quote">u can pop can it....just get a coke can etc. and make a gasket with it blocking the iac off make sure u make holes in it for the bolts to go through this works but may idle a little low car will not high idle in open loop though</TD></TR></TABLE>
...what?! are you kidding me....!?
Old Jun 6, 2006 | 06:50 AM
Default Re: Safe to drive with this check engine light? (redface)
aahhhh what...........
Old Jun 9, 2006 | 05:15 AM
redface's Avatar
don't knock it till you do it it works i know it sounds primitive and rediculous but hey just givin him an option i did it on ym friends ls eg coupe and my friends beater accord worked fine
Old Jun 14, 2006 | 08:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redface &raquo;</TD></TR><TR><TD CLASS="quote">don't knock it till you do it it works i know it sounds primitive and rediculous but hey just givin him an option i did it on ym friends ls eg coupe and my friends beater accord worked fine</TD></TR></TABLE>
still bad advice
Old Jun 15, 2006 | 07:45 PM
HatchEh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thahuhstunna &raquo;</TD></TR><TR><TD CLASS="quote">still bad advice</TD></TR></TABLE>
i second that...
ghetto fab= .....
Old Jun 15, 2006 | 10:17 PM
mmuller's Avatar
Mad Scientist
it looks like your iacv needs a bath..
if you by mistake were to swap connectors with some other sensor, you would be throwing more than 1 code...
maat4449
Honda CR-V & Element
Jan 7, 2011 08:08 AM
Costco
Sep 18, 2010 06:33 AM
skateboard c
Aug 11, 2006 08:32 AM
candy eg
10
May 18, 2006 11:24 AM
boosted spoon
Jul 23, 2002 12:08 PM
