input shaft bearing dumb question b series
Old May 17, 2006 | 08:30 PM
hugegastros's Avatar
Default input shaft bearing dumb question b series
if an input shaft bearing were to go out will this lock the trans??
Old Sep 4, 2007 | 05:34 PM
ricekiller1's Avatar
Default Re: input shaft bearing dumb question b series (hugegastros)
bump
Old Sep 4, 2007 | 11:07 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
possible, but not likely to 'lock' as you say.
Old Sep 5, 2007 | 06:30 AM
Wes V's Avatar
Default Re: input shaft bearing dumb question b series (not so civic)
My feeling is that the answer would be YES, although indirectly.
The reason for wording it that way is that when the bearing goes bad, the seperator between the ***** falls apart and those parts go all over the place inside the transmission. That junk could cause just about anything.
Wes
Old Sep 6, 2007 | 04:06 PM
slowcivic2k's Avatar
If the clearance is bad enough it could cause the mainshaft gears to clash with the countershaft, but I've never seen one do that. If it is very severe it will be hard to shift and maintain any gear.
Most of the time the ***** get trapped on the magnet, or in the general area, since the magnet is right below it. When it gets bad the snap ring bearing on the countershaft blows up too, and lodging the cage just behind the 3/8" sealing bolt on the end of the tranny that splits the case open.
What is the problem you are having?
95EG2
Jun 4, 2012 04:13 AM
ekhaze
Transmission & Drivetrain
Mar 25, 2011 01:57 PM
turbo00EK
May 13, 2009 05:03 PM
Wes V
22
Oct 25, 2003 12:51 PM
todapower
Jul 24, 2003 09:11 AM
