d series transmission input shaft bearing question
took my trans apart to replace the isb and when i have everything apart there are 2 small ball bearings just lay inside the transmssion and have no clue where they go... all the other bearing are intact even the isb... none of the bearings fell apart have no clue where they go any ideas anyone...
Re: d series transmission input shaft bearing question
these are the ball bearings to small of ball bearing for the isb and all the other bearing inside tanny
there from transmission casing, they keep the shift rods in place.
check the link for pics:
http://www.ek9.org/forum/transmissio...-*****-go.html
Seagull Management
S20s have the detent ***** in the aluminum forks. S40s have detent bolts in the case with the springs and ***** under the bolts.
prelude182
08-03-2009 05:53 PM
Wes V
22
10-25-2003 12:51 PM
