just bought 91 accord for gas mileage. but 22mpg?
Old May 17, 2006 | 07:44 PM
DA91TEGGY's Avatar
Default just bought 91 accord for gas mileage. but 22mpg?
ok i just bought a 1991 accord ex 5 speed 4 door, i bought it to get better gas mileage, and to be my daily driver.... ive measured last few times i went to the gas station i was only getting 22mpg...... whats everyone else getting, and what are somethings to get it a lil higher? just changed plugs n wires, no change
ps it has 205k
Old May 17, 2006 | 07:54 PM
rleonekc's Avatar
Default Re: just bought 91 accord for gas mileage. but 22mpg? (DA91TEGGY)
I've got a 90 and i get around 30 Mpg
Old May 17, 2006 | 08:03 PM
DA91TEGGY's Avatar
how? i am driving like a grandma too not taking it over 3500
Old May 17, 2006 | 08:16 PM
HONCORD's Avatar
Try to change your fuel filter, that will help. That things probably never been changed before and clogged da fk up.
Old May 17, 2006 | 08:20 PM
DA91TEGGY's Avatar
ill try the filter, but how would that affect the mileage, the gas is still going through it no matter what, if its clogged it might flow slower, which should ad mpg
Old May 17, 2006 | 08:49 PM
pos_cd5's Avatar
Default Re: (DA91TEGGY)
along with the fuel filter check and replace the air filter, and when was the last time it had a tune-up? putting in some new spark plugs, plug wires, and dist. cap and rotor wouldnt hurt. and make sure your alignment is good. try to keep it under 3k rpm, be easy on the gas. keep your windows rolled up on the freeway. and try some fuel system cleaner, i used some chevron techron and it bumped my MPG from 20 to about 23...i got a 95 lx 4cyl, im getting shitty low 20's mpg because i have really bad alignment, but the techron fuel system cleaner worked great.
Old May 17, 2006 | 10:08 PM
HONCORD's Avatar
Default Re: (pos_cd5)
he did say he replaced plugs n wires. Alignment kills your gas mileage? I know low tire pressure will, but alignment? I might have to research on that. I truly never heard of that yet.
Old May 17, 2006 | 10:34 PM
pos_cd5's Avatar
Default Re: (HONCORD)
yea, bad toe will create excessive friction and kill gas mileage and wear down your tires.
Old May 18, 2006 | 12:37 AM
Mangotreemechanic's Avatar
You haven't mentioned what kind of driving you do. Is it city or highway? Get a complete tune-up and service check-up. Do what you can yourself. That way you can see what the old condition was. Like changing the filters, air and gas.
I have a '90 4 cyl, and I get 24 mpg with suburb driving with part hwy commute.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA91TEGGY &raquo;</TD></TR><TR><TD CLASS="quote">ok i just bought a 1991 accord ex 5 speed 4 door, i bought it to get better gas mileage, and to be my daily driver.... ive measured last few times i went to the gas station i was only getting 22mpg...... whats everyone else getting, and what are somethings to get it a lil higher? just changed plugs n wires, no change
ps it has 205k</TD></TR></TABLE>
Old May 18, 2006 | 01:51 AM
92ehatch's Avatar
Default Re: just bought 91 accord for gas mileage. but 22mpg? (Mangotreemechanic)
get a full tune up, put a little more pressure in the tires as well.
my tune up:
new spark plugs, wires, dizzy cap, rotor, fuel filter, k&n filter, valve adjustment, seafoam treatment
tire pressure: 35 psi (honda recommends something like 30 for the cb7)
and of course get an alignment.
i get 30 - 35 mpg with a combo of city and highway driving, and i drive to run over grandma
Old May 18, 2006 | 04:31 AM
DA91TEGGY's Avatar
its mixture of city and highway, and i need an alighment bad, ive only had the car for a few weeks now, so far the only thing done was changed the alternator, battery, plugs, wires, its not a bad for for $500 body is mint and its a ex, only bad thing its burgendy, not really my color
Revolver123
Honda Civic (2001 - 2005)
Jun 11, 2008 08:45 AM
josephshark
103
Feb 2, 2006 09:03 AM
F22a1stick
Oct 13, 2005 03:31 PM
kelley
Apr 18, 2005 08:44 PM
NiBlazed
Oct 26, 2004 07:07 PM
