ZC Doch Garret t3/t4 Turbo question and recomendetion
Hi fellas i found a few turbos but i have a confusion
1. Turbo is a
GARRETT T3/T4E hybrid It has a 57 trim compressor wheel,50AR compressor housing and 63AR turbine housing with a stage three turbine wheel.It comes with a 10lb adjustable wastegate .They also come with a 360 degree bolt down thurst and only two companies make those Garrett and turbonetics.
2. Turbo a T3/T4E hybrid, remanufactured. It has a 57 trim compressor wheel,50AR housing and 48AR turbinewith a stage three turbine shaft.Garrett compressor wheel and shaft and garrett covers with all new garrett components.It also comes with a 360 degree bolt down thrust.
3. Turbo is a T3/T4E hybrid, remanufactured. It has a 57 trim compressor wheel,50AR housing and 48AR turbinewith a stage one turbine.Garrett compressor wheel and shaft and garrett covers with all new garrett components.It also comes with a 360 degree bolt down thrust.
here we go my questions wich of this 3 turbo is the best choice for my DOCH ZC and if somebody can explain me about which is the diferrence between a stage 1 and stage 3 turbo and also want to know what means when talk about TRIM and AR?? thanks in advance
1. Turbo is a
