can someone confirm the wire colors for the PSP power steering pressure switch (connector #311)
Old May 17, 2006 | 05:42 PM
RTW DC2R's Avatar
Default can someone confirm the wire colors for the PSP power steering pressure switch (connector #311)
I found the connector in the wire harness section (electrical, non-supplemental) in the helms, but didnt see the wire colors for it listed. Im pretty sure it only has 2 wires, green and black. It comes off the driver side of the harness on the lower portion of the shock tower, a few inches below the master cylinder.
thanks
Old May 18, 2006 | 08:17 AM
Padawan's Avatar
Darth ModerVader
Default Re: can someone confirm the wire colors for the PSP power steering pressure switch (clip the apex)
I'll take a look this evening for you if the information isn't given by then.
Old May 18, 2006 | 01:50 PM
Padawan's Avatar
Darth ModerVader
The wires are solid green and solid black. This is on a '98 ITR, but I assume it was the same on other years.
Old May 18, 2006 | 01:55 PM
RTW DC2R's Avatar
thanks man
<<< goes to cut that off
j_the_guy
Mar 10, 2019 11:33 PM
crazyboy
Mar 6, 2011 12:46 PM
prelude182
Feb 24, 2011 11:23 AM
integraXTC
Aug 4, 2005 08:27 AM
NobodysHero
Jul 10, 2004 08:10 PM
