1994 oil change... how to (need help asap)
Old May 17, 2006 | 05:22 PM
phatrabbitzz's Avatar
Default 1994 oil change... how to (need help asap)
Where's the oil filter on an 1994 honda accord 4cyl.?
How many quarts does it need?
Where is the engine oil tank?
TIA
Old May 17, 2006 | 05:29 PM
hondaracin24's Avatar
Default Re: 1994 oil change... how to (phatrabbitzz)
Its needs 4.5 quarts of oil. The oil pan is located under the engine. You might want to purchase a Helms manual so you know what your doing or have someone experienced do it the first time and show you how to do it since you dont know where anything is.
Old May 17, 2006 | 05:34 PM
Default Re: 1994 oil change... how to (hondaracin24)
Yea, I figured that's where the engine pan is at. But where's the actual filter at? For some reason I'm having a hard time finding it.
Old May 17, 2006 | 05:45 PM
Its located behind the engine block under your car. If look under your car you should be able to find it. It looks simaler to this: http://www.acdelco.com/parts/f...s.htm
Old May 17, 2006 | 05:46 PM
BLKFLSH's Avatar
It is between the engine and passenger compartment. Under the intake and over the exhaust pipe. PLEASE!!!!! DO NOT GET UNDER THE CAR WITH ONLY A JACK SUPPORTING IT. USE JACKSTANDS OR RAMPS. You will need a small filter wrench, to remove the filter.
PS: And if you plan to work on the car yourself, get a service manual. At least one of the cheap ones from Autozone, Advance.
Modified by BLKFLSH at 9:14 PM 5/17/2006
Old May 17, 2006 | 06:53 PM
75thRanger's Avatar
I changed the oil in my 95 about two months ago. I was only able to get the driver side on the one jack stand I had. I also turned the wheels about 3/4 to the right and then was finally able to see the filter. Lets just say if you had ramps or two jack stands it would be a lot easier.
Old May 17, 2006 | 07:05 PM
Default Re: 1994 oil change... how to (75thRanger)
Yea, that's what I was basically trying to do change the filter without lifting the car. Once I lifted it (on all four jackstands) all the rest fell in place.
Thanks
ross2004
Apr 30, 2024 10:12 AM
WingedMan
Aug 22, 2011 06:50 PM
hatchyboy89
Sep 17, 2005 05:14 PM
turbolag98
Sep 17, 2003 04:30 PM
greebler
20
Jun 6, 2003 01:17 PM
