CHECK ENGINE LIGHT PART 2 HELP!!!
Old May 17, 2006 | 05:10 PM
QuickRexSi21's Avatar
Default CHECK ENGINE LIGHT PART 2 HELP!!!
alright so last week i was driving home....check engine comes on, and the car pulls back for about a second, and the rpms shoot down, but right back up....i drive home, clean the battery connections because there was corosion on the positve end... the check engine comes off and the car feels fine...
today i was driving...the check engine came on...now the car wont go passed 4000 RPM, it will just start stuttering. anyone got any clue what this is about??? can it be the clutch slipping?? any info will help. thanks.
Old May 17, 2006 | 08:57 PM
k20tuner's Avatar
Default Re: CHECK ENGINE LIGHT PART 2 HELP!!! (QuickRexSi21)
It could be anything but it doesn't sound like something that can be fixed in the driveway. I would go to a mechanic and see if they will tell you whats wrong with it. Most of the time they won't charge you but you might have to wait untill they can get around to it.
Old May 18, 2006 | 06:05 AM
ekek888's Avatar
check the engine ground wire and move it to a better place. i think theres an article in hondata site about it. i hope this helps.
Old May 18, 2006 | 07:09 AM
t o m's Avatar
check engine ground. then reset ECU and see what happens
Old May 18, 2006 | 02:14 PM
Default Re: CHECK ENGINE LIGHT PART 2 HELP!!! (ekek888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekek888 &raquo;</TD></TR><TR><TD CLASS="quote">check the engine ground wire and move it to a better place. i think theres an article in hondata site about it. i hope this helps.</TD></TR></TABLE>
by any chance, do you have the website i can check that out on? thanks
Old May 18, 2006 | 02:35 PM
Default Re: CHECK ENGINE LIGHT PART 2 HELP!!! (integra type s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra type s &raquo;</TD></TR><TR><TD CLASS="quote">check engine ground. then reset ECU and see what happens</TD></TR></TABLE>
alright, the ground is connected to the same ground as the battery.... is there a different ground some where else? where should i relocate it? from where it hooks up from the tranny, or where it grounds from the battery?
Old May 18, 2006 | 03:04 PM
t o m's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QuickRexSi21 &raquo;</TD></TR><TR><TD CLASS="quote">
alright, the ground is connected to the same ground as the battery.... is there a different ground some where else? where should i relocate it? from where it hooks up from the tranny, or where it grounds from the battery?</TD></TR></TABLE>
theres a ground right behind the fuel rail. take it off and attach it to the valve cover
Old May 18, 2006 | 04:00 PM
theres a ground right behind the fuel rail. take it off and attach it to the valve cover</TD></TR></TABLE>
NOICE!!! alright, relocated the ground....check engine light off, car revs perfect. hopefully this was the problem. Oil light came on tho.....think its time to change it up... thanks everyone....ill keep you posted if more problems occur
Old May 25, 2006 | 02:17 PM
Okay so this wasnt the problem after all...i relocated the ground and today the check engine light came on again. again it wouldnt let me pass 4000 rpm...then i pulled to the side turned off the car and let it sit for a minute i turned it on, the check engine was still on but it would now let me go passed 4000rpm. i do notice a sight lag at 3 to 4000 rpm. kinda like a slip or missfire???? anyone got any ideas???? im stumped...im thinking of taking it to honda just to get a diagnostic.
Old May 25, 2006 | 07:47 PM
k20tuner's Avatar
Dude by know you might as well cut your losses and let Honda look at it cause it sounds like ignition trouble.
Old May 26, 2006 | 02:32 AM
ekek888's Avatar
when u reach 4k rpm does it feel the same as hitting the rev limiter?
here is the link for grounding the engine.
http://www.hondata.com/news.html
Old May 26, 2006 | 09:10 AM
dc5RickK20's Avatar
Default Re: CHECK ENGINE LIGHT PART 2 HELP!!! (k20tuner)
why dont you just go and get a code reader and find out for sure what that check engine light means.
Old May 26, 2006 | 11:04 AM
DJ_CARY's Avatar
Default Re: CHECK ENGINE LIGHT PART 2 HELP!!! (dc5RickK20)
Go to AUTOZONE !!!!!!
Borrow their OBD SCANNER and READ what's the problem , instead of guessing it!
Dont drive it until u know what's wrong with it!
Old May 26, 2006 | 03:03 PM
Default Re: (ekek888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekek888 &raquo;</TD></TR><TR><TD CLASS="quote">when u reach 4k rpm does it feel the same as hitting the rev limiter?
yeah thats what it feels like. i was also thinking maybe an 02 sensor??? im going to get a diagnostic tomorrow so that should tell me whats wrong with it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20tuner &raquo;</TD></TR><TR><TD CLASS="quote">Dude by know you might as well cut your losses and let Honda look at it cause it sounds like ignition trouble.</TD></TR></TABLE>
your right...im taking it in....it came on again today.
Old May 27, 2006 | 09:06 AM
bliss@5200's Avatar
my freind had the same problem. its emissons.
Old May 27, 2006 | 12:07 PM
Default Re: CHECK ENGINE LIGHT PART 2 HELP!!! (bliss@5200)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bliss@5200 &raquo;</TD></TR><TR><TD CLASS="quote">my freind had the same problem. its emissons. </TD></TR></TABLE>
what did he do to fix it?
Old May 27, 2006 | 05:50 PM
t o m's Avatar
what mods do you have?
Old May 27, 2006 | 05:51 PM
i checked my intake to check out the sensor on it. it was a bit loose with the rubber ring missing...then i pulled it out and it completley sucked the ring into the intake manifold. would this be a major problem?? and the cause of all the rest of my problems?
Old May 27, 2006 | 08:20 PM
dE.fUsEd's Avatar
you have to be kidding..
Old May 28, 2006 | 01:18 AM
boredfast's Avatar
you are seriously a ******* retard, no offense, you should really not even be on this webpage at all.
ok time to be nice:
FIRSTLY, if you ever have a CEL get it DIAGNOSED AS SOON AS POSSIBLE, which you obviously have not done. GO TO AUTOZONE. in 5 minutes you can KNOW what the problem is and the dude will probably be knowledgable enough to suggest some fixes.
STOP driving your car around every the expletive where. its apparent that your CEL will come on every time and put the car into limp mode. STOP TRYING TO REV IT.
CHECK YOUR OIL LEVEL. the oil gauge comes on if the level or PRESSURE (because in some cases there is NO oil) is out of spec.
Also, what the hell are yo udoing messing with sensors while the car is running?? Do that **** when its off!!!! judging from the rest of your post you probably didnt have the hindsight to NOT drive the car, so that rubber grommet is probably chillin somewhere.. hopefulyl melted in your IM and not in your comb. chamber.
IF You were smart enough to turn off the motor and not run it, then take off the intake and look beofre the throttle body or in your Idle air control valve for the rubber piece.
Old May 29, 2006 | 12:01 AM
Default Re: (boredfast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boredfast &raquo;</TD></TR><TR><TD CLASS="quote">you are seriously a ******* retard, no offense, you should really not even be on this webpage at all.
ok time to be nice:
first off... expletive you...who the expletive do you think you are to be calling anyone a ******* retard? the reason a website like this is made is to post topics and problems with cars, not to trash on eachother. do you just go on this to talk **** or to help??
I have to get to work you ******* retard, how the expletive else am i going to get there if i cant drive my car. sorry some of us have responsibilty and makes it hard to just stop what were doing when something goes wrong with our cars. accidents do happen and you dont have to be a dick and try to make someone feel worse about ****. either help with the problem..or shut the expletive up....
Old May 29, 2006 | 12:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra type s &raquo;</TD></TR><TR><TD CLASS="quote">what mods do you have?</TD></TR></TABLE>
just an intake....nothing else
greenDC2
Feb 25, 2005 09:41 AM
redludevtec
Aug 15, 2004 04:00 PM
