turbo? or gsr motor swap??
im thinking about either swapping motors or boosting my car
should i go with the gsr motor that has 87000 miles on it or i was gonna get a used turbo and just boosting my D16 motor
i have a 97 4 door civic lx
which way will be the best way to go?
it all depends how much you want to tune.... but honestly i would go with the gsr swap... itz a lot more reliable and a lot more you can do to it after
"The best way to go" all depends on what you plan to use the car for. From what I've heard and seen, you can put down around 200whp with a boosted d16 but at the same time a GSR motor has a lot more potential in the long run. COrrect me if I'm wrong because I'm still a noob myself
You should aslo consider what type of power you want. If you plan to go turbo you need to consider what type of mods to invest in.
Think of what you want to do with it in the future, what your budget will let you do with it and also what kind of power you want.
Dukie432
80
Dec 24, 2008 04:08 AM
danthemang3
Sep 28, 2008 04:29 PM
