Koni struts???
Old Apr 11, 2002 | 07:58 PM
Ham'ed Hatch
Guest
Posts: n/a
Default Koni struts???
can anybody tell me if Koni's for the 89-91 civic have a hiegth adjustable spring perch in the REAR? if so, in what incriments can the perch be lowered?
thanks!
Old Apr 11, 2002 | 08:31 PM
CRX7's Avatar
Default Re: Koni struts??? (HoMoCo FoLife)
Yes, there are five settings, and each notch is like a centimeter or two I'm not sure, I'll go look at it when I get home
Old Apr 12, 2002 | 10:30 AM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: Koni struts??? (CRX7)
i'm looking for one half to one inch more of a drop in the rear. so i could achieve that with Koni's???
Old Apr 12, 2002 | 05:00 PM
Ham'ed Hatch
Guest
Posts: n/a
anybody???
Old Apr 12, 2002 | 05:07 PM
jasyatz's Avatar
Not 5 notches but 3. Standard, Higher and lower. They are approx 1" apart..
For coil overs, I have mine all the way on top... When I had the standard springs on, were in the middle. Using the stock springs, you can set the rears on the bottom perch and will lower car approx 1" and retain the factory ride quality.
Old Apr 13, 2002 | 11:07 AM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: Koni struts??? (conetoy)
awesome thanks!
Old Apr 13, 2002 | 11:22 AM
CRX7's Avatar
Mine have 5, each is about a half inch apart. Part number is 8041-1153 Sport
Old Apr 13, 2002 | 03:11 PM
Ham'ed Hatch
Guest
Posts: n/a
are the SPORTs yellow or red???
Old Apr 14, 2002 | 03:16 PM
jasyatz's Avatar
Sports are yellow.
There are 2 different kind of Koni's the ones that can be adjusted with the strut installed, and the ones that require removal of the strut for adjustment...
I beleive the "remove and install" ones have more height adjustments...
The sports or "yellows" are they are more commonly know as, have only 3 settings (at least the current production off the shelf units do) single adjustables..
Old Apr 14, 2002 | 03:48 PM
carsaregood's Avatar
i agree, my yellow "sport" konis are externally rebound adjustable, and have 3 notches for height adjustment for BOTH front and rear.
Old Apr 14, 2002 | 04:02 PM
Aahj's Avatar
Default Re: Koni struts??? (carsaregood)
ditto
Old Apr 14, 2002 | 06:01 PM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: Koni struts??? (ajn)
so if i'm looking for half an inch of a drop, then i should get the RED non-external adjusting ones, they have more options???
all this is confusing...
herrgolf
39
Aug 24, 2017 10:30 PM
t_c_l_6
Suspension & Brakes
Mar 19, 2006 05:29 PM
AEGEAN
17
Dec 5, 2002 12:15 PM
Greyout
Dec 25, 2001 11:07 PM
