Black Out Headlights
Old May 17, 2006 | 03:22 PM
TheMuffinMan's Avatar
He knows where you live!
Default Black Out Headlights
I'm in the process of fixing damage to my accord (no idea how it happened) and figured I'd give the whole DIY black out headlights a go, now I have the actual piece up and out of the car and the black mounting bracket, taken off the metal clips, and undone everything there is to undo. I've read and been told to stick the sucker in the oven to heat up the glue that holds the glass with the plastic/reflective part, but haven't seen any real details on it. Would it be easier to use a heat gun and slowly pry it apart, or does someone who's done it have a suggestion as to what to heat my oven to and about how long it should stay in there? I don't want to put it in, melt the plastic and then be out of my headlights
Old May 17, 2006 | 04:19 PM
notoriousB's Avatar
Default Re: Black Out Headlights (TheMuffinMan)
heat gun works good too. what I've done in the past is to preheat the oven to 200*F, put the headlight(s) in there for 5-6 minutes, and then pry apart using a heat gun to heat up any stubborn parts.
Old May 17, 2006 | 04:35 PM
naoandlata's Avatar
Default Re: Black Out Headlights (notoriousB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB &raquo;</TD></TR><TR><TD CLASS="quote">heat gun works good too. what I've done in the past is to preheat the oven to 200*F, put the headlight(s) in there for 5-6 minutes, and then pry apart using a heat gun to heat up any stubborn parts. </TD></TR></TABLE>
Or you can stick it back in the oven for another minute or so and try again
Old May 17, 2006 | 04:51 PM
Alrighty thanks a bunch guys, I had a spare headlight I tested on to get the technique down, had some of the plastic blister a bit but nothing horrible so I'm starting on them now, thanks for the responses!
Old May 17, 2006 | 09:50 PM
Muh ahahha, oven @ 200 + heat gun action worked perfectly, I'll try to post pics up tomorrow I'm quite proud at how they turned out!
Old May 18, 2006 | 12:29 AM
. C h e n l a's Avatar
Default Re: (TheMuffinMan)
i plan on doin this, this summer
Old May 18, 2006 | 03:08 AM
Yep looks really nice, my only thing now is how I should do my corner lights.....
these:
http://cgi.ebay.com/ebaymotors...sting
or:
http://cgi.ebay.com/ebaymotors...ZWDVW
And how I should go about painting them
Old May 18, 2006 | 10:30 AM
Andryzzle's Avatar
depo makes some that you wont have to paint.
http://www.topendmotorsports.c....html
scroll down to accords and they are right there.
Old May 18, 2006 | 11:09 AM
I would probably end up paint those anyway, I"m going for this look :
http://img.photobucket.com/alb...0.jpg
Front turned out awesome I gotta figure out what to do on the corners
Old May 18, 2006 | 02:06 PM
Andryzzle's Avatar
i think you scrolled down too far... look at the bottom of the second picture
mine are DIY with the depo corners
Old May 18, 2006 | 05:19 PM
lxaccord51oxl's Avatar
Default Re: (Andryzzle)
i tried doing this before. i put the clear corners on a foil and it melted the sh*t out of the plastic, so i bought new corners. what do you guys use to place the lights on when it is in the oven? oh yea and when i try to pry it open, it jus made a crack down the middle of my corners...what did i do wrong?
Old May 18, 2006 | 07:14 PM
hmm lx, that's exactly what I did, I put a sheet of tin foil down on the oven grate, heated it up to 200o on Bake setting and set it in there for 5-6 minutes and pulled it out and took a flat head screwdriver and slowly pried, I had 0 melting issues while it was in the oven, what heat did you use and was there any moisture?
And thanks Andryzzle! That's exactly what I want, looks like I'll order some Depo's asap I had another question regarding your grill, is that like a JDM or EDM market grill or a DIY (paint the chrome mount the rear tag on a piece of it) because I love how that looks as well an my current one is fading
Old May 18, 2006 | 07:22 PM
Andryzzle's Avatar
one of those $10 "type-R" grills off ebay and the chrome "Accord" from the back. im pleased with it.
Old May 19, 2006 | 10:44 AM
first i used a wetted cardboard, put it in the oven and placed the corner on top of the board. i let it sit in there for 7 minutes and the glue wasn't melting off. so i tried using tin foil for another 3 minutes and it melted my plastic, but once i triedd to pry it open anyways, it cracked my corner...
Old May 19, 2006 | 10:50 AM
Andryzzle's Avatar
Default Re: (lxaccord51oxl)
i did my headlights myself, but bought the corners like muffin man is doing. the corners just didnt seem like they would be as easy.
Old May 19, 2006 | 12:34 PM
A R M E N .'s Avatar
If yo got any questions PM ME
ES1Goldieee
Honda Civic (2001 - 2005)
Sep 12, 2015 07:29 PM
boostedb16a3
Honda S2000
Sep 15, 2011 07:01 AM
JhonJhon619
20
Dec 28, 2010 09:28 AM
racin-type
Aug 12, 2004 02:21 PM
Jet Phi
Sep 21, 2002 02:46 AM
