does clutch pedal need to be adjusted after clutch swap?
Old May 17, 2006 | 03:18 PM
redpeppers's Avatar
Default does clutch pedal need to be adjusted after clutch swap?
just as the topic says....97 civic cx.....i am trying to find out why.....my car is not moving now after i did clutch kit swap......is it nessacary to do pedal adjustments after the swap
Old May 17, 2006 | 03:35 PM
BauleyCivic's Avatar
Risky Business
Default Re: does clutch pedal need to be adjusted after clutch swap? (redpeppers)
Mine didn't need adjusting...
Old May 17, 2006 | 04:29 PM
Archidictus's Avatar
Unceasing Measure
Did you bleed the clutch slave cylinder? The pedal shouldn't require any kind of adjustment. Also, you could have an axle only half-in its socket. That'll make it seem like some serious **** it wrong
Stonage07
Mar 6, 2017 11:48 AM
91ACCORD4GLX
Mar 23, 2013 07:46 AM
Boostin_GSR
Jun 3, 2007 11:34 AM
tvman
Jul 16, 2005 11:30 AM
