can anyone identify this mount
some more help needed... maybe somone can help with this too... i know i also need the mount that bolts under the timing belt cover but you reuse the d series rubber pieces.... well the b16a3 (del sol vtec) i purchased came with that mount on it.... it's pictured here
can i use that instead of buying the 99-00 si one? they look the same.
The timing belt side mount bracket that you have is wrong. Just order the one for a 99-00 Civic Si, and don't forget the studs, they are of a larger diameter than the ones in the mount bracket you have pictured. As for the rear mount bracket, it is hard to tell if that is the correct one, maybe placing a tape measure in the picture would help?
johnzy00
Dec 15, 2009 02:21 AM
CincyCichlids
Oct 6, 2009 04:21 PM
obuhmyuh
26
Nov 5, 2008 02:30 PM
too much vtAK
May 17, 2006 09:21 PM
