mini me vtec wiring i need help
if you are running a pr3 or pw0 ecu then you will have to connect 3 wires.
VTEC SOLENOID ----> BLUE WIRE ----> PIN A8 on ECU plug
(it might not have a wire there so you will
have to find a messed up harness and
take the wire from that one and slip it in)
VTEC PRESSURE ----> GREEN WIRE ----> PIN B5 on ECU plug
BLACK WIRE ----> Ground (ground to thermostat housing)
93(Civic)EG6
Aug 4, 2007 06:10 PM
lsvtecSIrex
Jun 14, 2006 03:13 PM
